liquid Posted September 4 Report Posted September 4 Hi everyone, I’ve been checking many threads about the “fill pod” warning on the Oxva Pro 2 DNA. Most people seem to have the opposite problem — they get frequent “fill pod” messages even when the pod still has plenty of liquid. But my device is the other way around. I’m using the SS coil, and when I insert the pod it shows “anti burn,” but I never get any “fill pod” warning at all. Because of that, I’ve already burned two pods. I’ve read a lot of replies and checked my settings in Escribe. Under Safety → Fill Pod, the feature is enabled, and I even set it to “High.” So my question is: Could this be a chip/firmware issue? My firmware version is 1.1 SP125.1 INT. Any help or insight would be appreciated🫶
Wayneo Posted September 4 Report Posted September 4 5 hours ago, liquid said: So my question is: Could this be a chip/firmware issue? My firmware version is 1.1 SP125.1 INT. You should update to the latest version (last post). Link in my signature line. I've never had that issue with any pod and you missed it could be a coil issue.
liquid Posted September 5 Author Report Posted September 5 (edited) 20小时前,韦尼欧说: 你应该更新到最新版本(最后一篇帖子)。链接放在我的签名线中。我用任何烟弹都没遇到过这个问题,你没注意到,可能是线圈问题。 我更新了固件,为了判断问题是芯片还是线圈引起的,我拆开了一个烧毁的烟弹,只保留线圈。然后我点火,带着那个线圈,这次它正常显示了“加注舱”警告。 所以看起来芯片和线圈都正常工作。 也许问题是我自己用得好,而不是硬件或固件的问题。 VID_20260905_222402.mp4 Edited September 5 by liquid
suuub Posted November 3 Report Posted November 3 Hello there, me and my friend both recently bought two oxvas xlim pro 2 dna kit, and we were intrigued by this antiburn feature, but recenly i was almost empty on the coil with no liquid at all, but the pod made me keep vaping with zero warnings or fill pod messages, leading to a burnt flavour. and sometimes with replay on i randomly get fillpod even when the pod is full, exiting from replay fixes it. the software im on is v.130.1
James Posted Thursday at 03:59 PM Report Posted Thursday at 03:59 PM @suuub, when it comes to Replay, the Fill Pod settings are (in my personal opinion) overly sensitive on Oxva. You can change them, though. If you install EScribe, go to the Mod tab, Atomizers, and then lower "Fill Pod Min Power (with pressure, Replay)". As to the coil that was almost empty, by any chance, had you put the coil on when it was hot?
suuub Posted Thursday at 05:13 PM Report Posted Thursday at 05:13 PM (edited) @James hi, thanks for replying, and for the tip about the replay! and as for the coil, yes maybe i was vaping and i took it out as i noticed it was almost with no liquid, i do it frequently. Maybe that's related? also, im having a new error now, trying to connect the vape with escribe, as soon as i plug the usb cable and escribe detects the vape, pressing ok makes the program freeze for a bit then getting this message: the device is in use any clue about how i can fix it? thank you so much! %7BfileStore.core_Attachment%7Dmonthly_2026_11/image.png.07df1e7e2e640dea5be43d9f179ad6d6.png Edited Thursday at 05:14 PM by suuub
