nicoparkk Posted Friday at 03:01 PM Report Share Posted Friday at 03:01 PM Hi. I'm using a clone Billet Box DNA60c. There was no problem when I usually used 0.8 ohm 20 watts for MTL, but Temp warning is displayed from about 25 watts when 0.28 ohm is signed to the steamshell.(Watt mode) It was the same when the same coil was used on different bridges. Is there a problem with my chipset? Link to comment Share on other sites More sharing options...
dwcraig1 Posted Friday at 03:30 PM Report Share Posted Friday at 03:30 PM Would you post a snippet of your device firing in Device Monitor like this one of mine? Maybe include you board and room temperatures in your post as well as your coil material. Link to comment Share on other sites More sharing options...
Wayneo Posted Friday at 04:03 PM Report Share Posted Friday at 04:03 PM @nicoparkk Check your coil. No problem with your chipset. 1 Link to comment Share on other sites More sharing options...
nicoparkk Posted Saturday at 01:48 AM Author Report Share Posted Saturday at 01:48 AM (edited) I used pmc coil 0.28 ohm and it worked fine on other instruments. Mod Resistance was set around 0.15, as the displayed resistance value was held higher than the actual resistance value. Is it related to this? Edited Saturday at 01:50 AM by nicoparkk Link to comment Share on other sites More sharing options...
Wayneo Posted Saturday at 02:13 AM Report Share Posted Saturday at 02:13 AM 11 minutes ago, nicoparkk said: I used pmc coil 0.28 ohm and it worked fine on other instruments. Never heard of this coil. 12 minutes ago, nicoparkk said: Mod Resistance was set around 0.15, as the displayed resistance value was held higher than the actual resistance value. What 'mod resistance'? Are you talking about escribe -> mod -> electrical -> mod resistance? The left side of your screen looks nothing like the right side. Left side shows: 16watts, 0.984Ω coil. Right side shows: 31watts, 0.219Ω coil. Battery voltage drop while firing looks terrible. If that is a .28Ω coil, re-measure the resistance of the coil on the mod. Link to comment Share on other sites More sharing options...
nicoparkk Posted Saturday at 02:24 AM Author Report Share Posted Saturday at 02:24 AM 5 minutes ago, Wayneo said: What 'mod resistance'? Are you talking about escribe -> mod -> electrical -> mod resistance? Yes, that's what you said. 6 minutes ago, Wayneo said: The left side of your screen looks nothing like the right side. Left side shows: 16watts, 0.984Ω coil. Right side shows: 31watts, 0.219Ω coil. I've already broken up the bridge. So that's what happened to get the recorded data I wrote yesterday. The right side is the data that had the problem. 10 minutes ago, Wayneo said: Battery voltage drop while firing looks terrible. What should I do to solve this? Link to comment Share on other sites More sharing options...
dwcraig1 Posted Saturday at 03:36 AM Report Share Posted Saturday at 03:36 AM 1 hour ago, nicoparkk said: 1 hour ago, Wayneo said: Battery voltage drop while firing looks terrible. What should I do to solve this? Your battery voltage drop. Either your cell is really weak or there is a poor connection between battery and board. If this battery works well in another mod then check that it's tight enough against battery contact. Check all battery connections are clean. With a load of 27 - 32 watts I would expect to see voltage drop to about 3.8 volts or higher with a cell that's nearly fully charged. Link to comment Share on other sites More sharing options...
dwcraig1 Posted Saturday at 03:44 AM Report Share Posted Saturday at 03:44 AM Your mod resistance of 0.15 ohm is way off from what would be expected, how did it get set to that? Default setting is 0.004 ohm so actual measurement shouldn't be very far from that. I can imagine something like 0.012 ohm but not 0.15 ohm 1 Link to comment Share on other sites More sharing options...
nicoparkk Posted Saturday at 08:54 AM Author Report Share Posted Saturday at 08:54 AM Initialized all settings. I don't think the battery is the problem. I'm using it normally on other devices. BATT warning was added to my symptoms in addition to TEMP warning. I tightened the drip tip loosely and it ignites, but something is off. It works normally when using 0.8 ohm coil for tmd boro. Is there a problem with the contact point? Link to comment Share on other sites More sharing options...
Wayneo Posted Saturday at 12:30 PM Report Share Posted Saturday at 12:30 PM 21 hours ago, nicoparkk said: I'm using a clone Billet Box DNA60c. What manufacturer makes this? Post link. 21 hours ago, nicoparkk said: ....... when 0.28 ohm is signed to the steamshell.(Watt mode) So is that a hand wrapped coil in an RBA or a stock coil in a bridge? Did you change "mod resistance" ? How did it get to 0.15? And what is it now? I need you to use 'escribe' words. What do you mean by "Initialized all settings." ? What do you mean by " .... something is off." ? Finally, I'd like to see a FULL Device Monitor screenshot like DWCraig posted way up top, with only these 5 parameters clicked. Link to comment Share on other sites More sharing options...
nicoparkk Posted Sunday at 01:15 AM Author Report Share Posted Sunday at 01:15 AM Sorry, wrong words because I'm using a translator. The manufacturer is JHFWI. This coil is a fused clapton, handcrafted coil. 12 hours ago, Wayneo said: What do you mean by "Initialized all settings." ? What do you mean by " .... something is off." ? Initialized all settings -> Restore Defaults This data is when the drip tip is loosely tightened. When tightened, the BATT warning is on display. Link to comment Share on other sites More sharing options...
Wayneo Posted Sunday at 03:41 AM Report Share Posted Sunday at 03:41 AM Thank you for all that you cleared up. Yesterday your Device Monitor showed differently to today. When you pushed the fire button, the voltage dropped (as it should) Today when you pushed the fire button, the voltage went up, no sag (which is backwards/odd/wrong) and it shows your coil losing resistance while it should be staying the same or increasing. Yet you say your 0.8Ω stock coil works fine. Do you have any other RBA's you could try in this mod OR any other DNA's you can try with this RBA? That drip tip should always be snug, not superman tight. Link to comment Share on other sites More sharing options...
nicoparkk Posted Sunday at 11:10 AM Author Report Share Posted Sunday at 11:10 AM I only have one device. I used a different rba. I used a ni80 fused clampon and 0.55 ohm was measured on the ohmtap. Why is there a resistance difference between Omtap and dna chipset? It works good. I can only think that there's a problem with the pmc coil. But when I bought this from shop, I saw rba that had my issues working normally on other devices. That's why I'm asking you for answers. Link to comment Share on other sites More sharing options...
Wayneo Posted Sunday at 12:00 PM Report Share Posted Sunday at 12:00 PM That DM screenshot looked much better. AGAIN 23 hours ago, Wayneo said: Did you change "mod resistance" ? How did it get to 0.15? And what is it now? I believe you started with a SteamShell RBA. What RBA did you use for the above? Link to comment Share on other sites More sharing options...
nicoparkk Posted Monday at 11:30 AM Author Report Share Posted Monday at 11:30 AM 23 hours ago, Wayneo said: Did you change "mod resistance" ? How did it get to 0.15? And what is it now? Yes. When tmd boro was used, the ohms of the device were displayed about 0.15 higher than the coil. So I adjusted mod resistance, but now I'm back to the default setting of 0.004. This rba is also steamshell. 1 Link to comment Share on other sites More sharing options...
dwcraig1 Posted Monday at 01:42 PM Report Share Posted Monday at 01:42 PM So now is the live ohms higher or lower than the cold ohms in Device Monitor when firing? Link to comment Share on other sites More sharing options...
