king aries Posted November 3 Report Share Posted November 3 Can someone guide mo on installing typc c port on dna60c Link to comment Share on other sites More sharing options...
Wayneo Posted November 3 Report Share Posted November 3 Using this diagram, follow pins 11-15 *Take note of pin 15. 2 Link to comment Share on other sites More sharing options...
king aries Posted November 3 Author Report Share Posted November 3 isee so dna60 and dna60c are the same? Link to comment Share on other sites More sharing options...
Wayneo Posted November 3 Report Share Posted November 3 Yes Link to comment Share on other sites More sharing options...
king aries Posted November 6 Author Report Share Posted November 6 gonna ask about this one it says swd 10 swc confuse about how to connect Link to comment Share on other sites More sharing options...
Wayneo Posted November 6 Report Share Posted November 6 How can I help when that IS NOT an Evolv product? Find the pin layouts on line, or ask the manufacturer. This is now the third connector you are inquiring about, what happened with the connector from a few days ago? 1 Link to comment Share on other sites More sharing options...
king aries Posted November 6 Author Report Share Posted November 6 it's not fitted to the mod Link to comment Share on other sites More sharing options...
king aries Posted November 7 Author Report Share Posted November 7 habing a hard time Link to comment Share on other sites More sharing options...
AuthorVapes Posted November 9 Report Share Posted November 9 Temporary solution: unstable, but usable 1 Link to comment Share on other sites More sharing options...
RicketyPumpkin Posted November 16 Report Share Posted November 16 On 11/9/2024 at 11:43 AM, AuthorVapes said: Temporary solution: unstable, but usable oh god. This burns my eyes to see. Please, nobody do this. how expensive is a replacement evolv charging board? I have a 250C so idk what they cost, however, I know it can't be that much that you should run janky as this pic. Not even any type of protective measure from shorting on the pins against each other? I wouldn't run something this janky and sketchy for money. No solder mask over the points of connection? Not even any electrical tape to spare? Whew, God bless you sir. 1 Link to comment Share on other sites More sharing options...
dwcraig1 Posted Sunday at 12:13 PM Report Share Posted Sunday at 12:13 PM Oh so that's how you hook up a charger board on a DNA60/60C that doesn't come with one or have room for one so that it can be connected to EScribe to make changes and/or update the firm ware.I was wondering how folks were doing it. 1 Link to comment Share on other sites More sharing options...
Biglion Posted Sunday at 02:15 PM Report Share Posted Sunday at 02:15 PM (edited) There is an USB-C dongle to buy, just for use or Connect it to your PC, it works very well, it is called DNA60 / DNA60C / Billet box Update Dongle by Stealthvape....if you want to try it like that...maybe this helps. Edited Sunday at 02:16 PM by Biglion Link to comment Share on other sites More sharing options...
AuthorVapes Posted Monday at 02:12 AM Report Share Posted Monday at 02:12 AM 在 2024/11/17 在 AM3點54分, RicketyPumpkin說: oh god. This burns my eyes to see. Please, nobody do this. how expensive is a replacement evolv charging board? I have a 250C so idk what they cost, however, I know it can't be that much that you should run janky as this pic. Not even any type of protective measure from shorting on the pins against each other? I wouldn't run something this janky and sketchy for money. No solder mask over the points of connection? Not even any electrical tape to spare? Whew, God bless you sir. I used electrical tape in practice, but I still don't recommend emulating this connection method. Link to comment Share on other sites More sharing options...
Thumper-77 Posted Tuesday at 12:57 AM Report Share Posted Tuesday at 12:57 AM (edited) Here is a schematic of a dongle that works with 60C. Only the 10K resistor is important, but a battery connection is required. I took a 3.5V stabilizer and assembled everything into a compact case. Spring-loaded contacts provide good contact with the board and do not require soldering. Edited Tuesday at 12:58 AM by Thumper-77 Link to comment Share on other sites More sharing options...
Biglion Posted Tuesday at 01:48 AM Report Share Posted Tuesday at 01:48 AM (edited) 2 versions you can get by Stealthvape, if you can't or won't solder. This is not an advertisement, for experienced ONLY. Do not try this at Home Edited Tuesday at 01:59 AM by Biglion Link to comment Share on other sites More sharing options...
