Hello,
The MOD mentioned in the title arrived a few days ago.
My problem would be that it charges to 97% every morning. That's fine too. But it falls off after a few puffs
this number is 90-80.....so it drains pretty quickly. I charge it with a 2A charger. and I use it with a Titan V2 at 100W.
Between 5 and 6 in the afternoon, it runs out of cocoa. Can someone help me what could be the problem?
Thank you very much in advance!
A Hadron Pro vaping at 100 watts and lasting about 9 hours? Sounds about right for those 4 cell 1600mAh lipos. Which lasts just as long as a DNA250C using two 21700 @ 3200mAh. The fast battery drop after charging is also perfectly normal too.
4 hours ago, Getroitz said:
It's fine then. Only someone said that he could last a day and a half with these same parameters.
That's why I invested in it.
I bet he consumed the same amount of juice in a day and half that you do (including myself) in 9 hours. Sometimes getting a second opinion really pays off.
But don't think of these 9 hours as a massive push.
Me either to be honest. But that's not to say that the Hadron Pro is awful or anything. After all, it is a good mod and all and one of the few that can do 400 watts quite easily. And pulling 100 watt vaping like you and I vape for 9 hours is still very respectable. The longest lasting per charge mods that I own are probably my two Vaperz Cloud HOG DNA400C (it's really using a DNA250C) using four 18650 cells. With 3000mAh cells, we could vape for about 15 hours at 100 watts. It is heavier than a Hadron Pro, but shorter. And that is about the best you are going to do for battery life. Unless you DIY your own mod that is bigger and heavier.
I was confident it wouldn't run out of power in the middle of the day because I was pretty much busy with Titan PWM from morning till night.
6 minutes ago, dwcraig1 said:
A 4 cell 1600 mAh lipo is 23.68 Wh
4 3000 mAh 18650's are 44 Wh
Quite a difference there.
yeah , thats true:)
Thanks a lot for your help!
