Steez Posted March 18, 2022 Report Posted March 18, 2022 Hello, after a few puffs my boro section is getting hot. Didnt do the chip update. Only changed idle time and put boost to 1. The mod is a bbvn df mod. I didnt have that problem in the beginning. Running an alien 2,5 at 22/25w with a 0,56/0,67 resistance. Thanks for the help!
Wayneo Posted March 18, 2022 Report Posted March 18, 2022 You might want to post in a more BBVN specific group about your issues, or even with BBVN directly. It could be the bridge/rba or anything really. Have you tried a different bridge/rba? How did you even notice a hot boro section?
Steez Posted March 18, 2022 Author Report Posted March 18, 2022 Hello thanks for the answer. bbvn told me to go to evolv forum to ask. I changed coil to a stagg same thing. How do i revert to the old chipset version software? I did a restore defaults but i dont know if it put the old chipset software version back.
Wayneo Posted March 18, 2022 Report Posted March 18, 2022 If you only ever changed the idle time and put boost to 1, I can't see either of those causing your hot boro. It does not sound like a board problem to me. It's the first time BBVN has ever been mentioned (if you search here yourself). If you start escribe with your mod plugged in, under the top line 'Help' tab you should see 'Backups' which were created. You can restore to any one of them. If you look under 'Tools' you'll see Apply service pack, and there should be 3 of them. I'd suggest the latest 'INT' version. You can see your current SP by starting Device Monitor and it shows down in the bottom right hand corner. I still suggest you might want to post in a more BBVN specific group about your issues. It could be the bridge/rba or anything really. Have you tried a different bridge/rba not just your coil. Luckily everyone here is free to comment with their thoughts.
dwcraig1 Posted March 18, 2022 Report Posted March 18, 2022 Make sure that the threads are clean on the top of the box (both parts). Check all connections related to coil.
Steez Posted March 18, 2022 Author Report Posted March 18, 2022 10 minutes ago, dwcraig1 said: Make sure that the threads are clean on the top of the box (both parts). Check all connections related to coil. All checked i didnt have the issue in the beginning … i recheck thanks 😇
Steez Posted March 18, 2022 Author Report Posted March 18, 2022 2 hours ago, Wayneo said: If you only ever changed the idle time and put boost to 1, I can't see either of those causing your hot boro. It does not sound like a board problem to me. It's the first time BBVN has ever been mentioned (if you search here yourself). If you start escribe with your mod plugged in, under the top line 'Help' tab you should see 'Backups' which were created. You can restore to any one of them. If you look under 'Tools' you'll see Apply service pack, and there should be 3 of them. I'd suggest the latest 'INT' version. You can see your current SP by starting Device Monitor and it shows down in the bottom right hand corner. I still suggest you might want to post in a more BBVN specific group about your issues. It could be the bridge/rba or anything really. Have you tried a different bridge/rba not just your coil. Luckily everyone here is free to comment with their thoughts. Ill check all that man i appreciate your help. Yes tried a different bridge even cleaned all my bridges with ultrasonic cleaner dried recoiled … same stuff… put in a 0,66 ohm alien at 21w and same thing …
