MetalVape90 Posted September 15, 2021 Report Posted September 15, 2021 Hey does anybody know which USB charging/data transfer chip I need for a DNA40 board? Just a while back I managed to get a VaporShark rDNA40 from the Planet of the Vapes forum, still works but it’s showing signs of ageing. The USB has seen heavy use and has fallen apart, the wireless charging feature still works and I there might be a grounding fault in the mod cause it doesn’t read the correct resistance of the atomiser. It’s a restoration project, trying to save the mod and bring it back to its former glory, that includes a new rubberised paint job. I was planning of putting a DNA60 in but I want to try and keep it original like it was out of the factory. Any advice will help with this.
BillW50 Posted September 15, 2021 Report Posted September 15, 2021 Sounds like you are looking for one of these. Evolv 1A Micro-USB Data/Charging Board https://www.protovapor.com/product/evolv-1a-micro-usb-datacharging-board/ Unfortunately Protovapor is out of stock. But this is what you might be looking for. They do have the DNA60 board in stock that does come with the charging board if you want to go that route. https://www.protovapor.com/product/evolv-dna-60d-retail-box/
MetalVape90 Posted September 15, 2021 Author Report Posted September 15, 2021 (edited) 1 hour ago, BillW50 said: Sounds like you are looking for one of these. Evolv 1A Micro-USB Data/Charging Board https://www.protovapor.com/product/evolv-1a-micro-usb-datacharging-board/ Unfortunately Protovapor is out of stock. But this is what you might be looking for. They do have the DNA60 board in stock that does come with the charging board if you want to go that route. https://www.protovapor.com/product/evolv-dna-60d-retail-box/ I’ll check them out, but since I’m in the UK my fellow apes from the Planet of the Vapes Forum have said to try https://www.stealthvape.co.uk/ since their in the mod making department. I’ll have a surf round. Edited September 15, 2021 by Classic_Mod_Collector 1
BillW50 Posted September 15, 2021 Report Posted September 15, 2021 Oh yes, the UK has better options. 😉
retird Posted October 31, 2021 Report Posted October 31, 2021 On 9/15/2021 at 8:32 AM, Classic_Mod_Collector said: Hey does anybody know which USB charging/data transfer chip I need for a DNA40 board? Just a while back I managed to get a VaporShark rDNA40 from the Planet of the Vapes forum, still works but it’s showing signs of ageing. The USB has seen heavy use and has fallen apart, the wireless charging feature still works and I there might be a grounding fault in the mod cause it doesn’t read the correct resistance of the atomiser. It’s a restoration project, trying to save the mod and bring it back to its former glory, that includes a new rubberised paint job. I was planning of putting a DNA60 in but I want to try and keep it original like it was out of the factory. Any advice will help with this. From my archived notes: How to get the DNA40 to re-set the TP resistance reference: Turn down to 1W, turn off TP, fire mod in wattage mode, disconnect atty, turn TP mode back on, put atty back on. Should clear the TP reference and re-read. Note: This is rarely actually required and does not indicate something wrong with the board. 1
