Yes! You have to tell EScribe you are using 2 cells for starters. Then you have come up with a fake shorted cell and insert in the cell 3 slot (I used a 65mm long fat bolt and fit it in something like a foam sleeve). Or instead of a fake cell, move the third cell positive battery lead to the cell two positive spot. Still want to do it?
2 horas atrás, BillW50 disse:
thank you for sure i want and i will do it!!
Are you using it like this? Where do I put the screw? In one of the negative cells down?
1 minuto atrás, BillW50 disse:
I only did it to see if it would really work like it did on paper. And it worked perfectly. Which Triade do you own? A DNA200, 250, or 250C?
mine is 250c
2 minutos atrás, BillW50 disse:
Can you use it safely?
Looking at the back of the Triade DNA250C, the back right 18650 cell is the third cell. Insert bolt in that one with insulation on the sides until it is the same size as a 18650.
In EScribe, select Options -> User Interface -> Manufacture. Then connect and download settings and select the Mod tab. Change from 3-cell to 2-cell and then Upload settings to Device. All done.
4 minutos atrás, BillW50 disse:
I can't see that video for some reason.
yes I'm not able to load either, I'll do what you said and then I'll give you a feedback, thank you friend! helped me a lot!!
  • Wayneo changed the title to Can i use Triade with two batteries only?
