Ahmed Nagy Posted June 19, 2021 Report Posted June 19, 2021 Good morning fam i have thelema dna 250c and I noticed that boost not working while I press fire to see changes on the screen! But the number on watt not change as it used to be! boost is on and punch on 5 atty is pioneer mtl rta please advice 🙏
dwcraig1 Posted June 19, 2021 Report Posted June 19, 2021 For starters make sure that you uploaded settings to device. Make sure that you are using the desired profile. Use EScribe's Devise Monitor to check wattage output when firing.
Ahmed Nagy Posted June 19, 2021 Author Report Posted June 19, 2021 (edited) Thanks for fast reply I just received the mod 2 days ago and never messing with anything yet is that normal that boost not working as a new device? profile is watt Edited June 19, 2021 by Ahmed Nagy
Ahmed Nagy Posted June 19, 2021 Author Report Posted June 19, 2021 Well i will do it when I arrive home any tips or something to out on my consideration when am on Escripe thanks for help I appreciate it 🙏
dwcraig1 Posted June 19, 2021 Report Posted June 19, 2021 Perhaps save your current configuration. Under File/Save As
Ahmed Nagy Posted June 19, 2021 Author Report Posted June 19, 2021 2 minutes ago, dwcraig1 said: Perhaps save your current configuration. Under File/Save As Thanks i will look at it 🙏
dwcraig1 Posted June 19, 2021 Report Posted June 19, 2021 Oh, I seemed to have overlooked this, make sure that you are using the International firmware. In the bottom right lower corner of Device Monitor will show the current firmware that's being used.
Ahmed Nagy Posted June 19, 2021 Author Report Posted June 19, 2021 3 hours ago, dwcraig1 said: Oh, I seemed to have overlooked this, make sure that you are using the International firmware. In the bottom right lower corner of Device Monitor will show the current firmware that's being used. Yah i will put that in my consideration and also am gonna restore it to default and try here and there to figure out the problem .. thanks for that I appreciate it .. have a great day 🙏
dwcraig1 Posted June 19, 2021 Report Posted June 19, 2021 If the firmware is the US version that is the problem. Restore to default as last resort and only after you saved your original configuration.
Ahmed Nagy Posted June 19, 2021 Author Report Posted June 19, 2021 1 hour ago, dwcraig1 said: If the firmware is the US version that is the problem. Restore to default as last resort and only after you saved your original configuration. Yah i will make sure that it international version but there’s a question , why us version not allowed boost features?
dwcraig1 Posted June 19, 2021 Report Posted June 19, 2021 Federal laws, the government thinks we should smoke tobacco and pay the taxes on the cigarettes. Nothing new was allowed the be added to an existing product. Every piece of your vape is considered nicotine in the US. The ;land of the free.......right?
Ahmed Nagy Posted June 19, 2021 Author Report Posted June 19, 2021 20 minutes ago, dwcraig1 said: Federal laws, the government thinks we should smoke tobacco and pay the taxes on the cigarettes. Nothing new was allowed the be added to an existing product. Every piece of your vape is considered nicotine in the US. The ;land of the free.......right? So the us version makes the chip like any other Chinese chips i got it .. i will see if my device on international or us version and if it’s on international so there’s a problem right?
dwcraig1 Posted June 19, 2021 Report Posted June 19, 2021 It just keeps the software as is till the application to the government is approved or denied, Things had to stay as they were from US vape manufacturers till the cutoff date. Note Evolv sell nothing to individual any longer. The software is considered nicotine. Even zero nicotine e-liquid is considered nicotine. The big tobacco companies have their vape products for sale all over.
Ahmed Nagy Posted June 19, 2021 Author Report Posted June 19, 2021 1 minute ago, dwcraig1 said: It just keeps the software as is till the application to the government is approved or denied, Things had to stay as they were from US vape manufacturers till the cutoff date. Note Evolv sell nothing to individual any longer. The software is considered nicotine. Even zero nicotine e-liquid is considered nicotine. The big tobacco companies have their vape products for sale all over. Understood yah
Wayneo Posted June 19, 2021 Report Posted June 19, 2021 23 minutes ago, Ahmed Nagy said: i will see if my device on international or us version and if it’s on international so there’s a problem right? Rarely a board or mod problem. More of a user setting or theme misunderstanding/issue.
Wayneo Posted June 19, 2021 Report Posted June 19, 2021 28 minutes ago, Ahmed Nagy said: So the us version makes the chip like any other Chinese chips i got it .. China has not followed American rules/laws. They still try to innovate, but this software suite is still arguably the best from any mfgr, in terms of TC, settings, tools. In fact, it's soooo good, the Russians made a knock of it. Till Replay came along. 1
CMK Posted June 19, 2021 Report Posted June 19, 2021 vor 8 Stunden schrieb dwcraig1: Use EScribe's Devise Monitor to check wattage output when firing. Es gibt hier auch diverse Themes, welche sowohl die Boost-Einstellungen zuverlässig anzeigen, als auch die Leistungsabgabe des letzten Puffs sauber dokumentieren. vor 1 Stunde schrieb Wayneo: More of a user setting or theme misunderstanding/issue. Sehe ich genauso - häufig werden Funktionen des Chipsatzes falsch implementiert, oder korrelieren nicht mit den Werkseinstellungen. Boost, Punch, Preheat, Replay - bei Problemen ist meist ein fehlerhaftes Theme, oder/und ein Missverständnis über die Funktionsweise die Ursache. Um welches Theme es sich hier handelt, wurde noch gar nicht erwähnt.
Ahmed Nagy Posted June 19, 2021 Author Report Posted June 19, 2021 Thanks guys it worked after i made restore to default 🙏 1
Amjad Posted July 16, 2022 Report Posted July 16, 2022 On 6/19/2021 at 8:59 PM, Ahmed Nagy said: Thanks guys it worked after i made restore to default 🙏 I have the same problem, when i hit the fire the watt doesn't xhange, but if i hit it in diagnostics it the watt boost, is it normal, i tried to reset it and its a new thelema 100c mod i have it for 1 day
Amjad Posted July 16, 2022 Report Posted July 16, 2022 It shows that the watt changes higher when i hit the fire then it settle back to the preset watt, but the device monitor stays the same watt with no changes, i guess its from the default theme
Amjad Posted July 17, 2022 Report Posted July 17, 2022 I'll try after work and update u but really appreciate ur fast reply
