Roxii Posted March 10, 2021 Report Posted March 10, 2021 Hello there, I am a visually impaired user, totally blind. I need a custom theme for my Dovpo Odin250c looking to have a very basic theme made where most settings are not accessible. Such as the top down and select button I am not really able to change the wattage or temperature on the fly because I cannot see the screen so if those could be disabled it would be great, I do use the 904L stainless steel coil‘s in temperature control that I have set up on the E scribe right now.. Any ideas where I can download a theme such as this? What’s appreciate it thanks.
Wayneo Posted March 10, 2021 Report Posted March 10, 2021 Welcome The Evolv default is what was shipped with your mod (I believe) with changed text for warnings and errors. While I understand your sight challenges, someone should be able to change those parameters on your behalf. I really cannot think of such a super basic, stripped down theme like you desire. You cannot lock buttons, but we can make fields display only. Just trying to hash out your requirements ............... Can you see really large text? Is there any special reason you're using temperature control? That's 3 things to set. A material profile, a temperature and a maximum watts. We/you can't really hide the 8 profiles, but we can make them harder to get at. Same for the temperature and watts.
Roxii Posted March 11, 2021 Author Report Posted March 11, 2021 Hi there, no I have no vision for the most part I can see some shadow movement if it’s close but that’s really about it so nothing that is useable in this context. Reason that I am using temperature control is the added safety of if I somehow press the fire button wallet is in my pocket and not locked. Hi there, unfortunately no I do not have any site that would be useful in this context, I can see movement of shadows that are close up but that’s really about it so nothing useful in this context. Reason that I’m using temperature control is that I like the added safety of having it so that it will not set fire to my pocket if I forget to lock the fire button and have the Vape in my pocket, and yes I did have this happen with a previous fight before was not fun. Also I am using the free Max mesh pro fee to CRC with the 904L stainless steel coils. I do have on my phone an app that can read out text to me now I can’t read everything that is on the screen if the tax gets very small but if the text is large yes it well read it out to me ours being relative for example no smaller than a 10 point print it out font. Obviously this being said I don’t need it with any kind of graphics as I’m not going to be seeing them. So as for anything displayed it needs to be in written format for example having a battery graph would not be useful as the screen reader on my phone would not read that I will but it would be able to say something like 93% or whatever the battery level is at. Anything else I missing shoot of reply in here and I can send you a reply.
zark Posted March 11, 2021 Report Posted March 11, 2021 Вашу просьбу невозможно реализавать на платах Evolve, единственное, что можно посоветовать, это настраивать мод с помощью приложения Escribe и не менять настройки при использовании. Но у меня есть знакомый, который плохо видит, он использует мод YiHi с управлением со смартфона с помощью блютуз соединения.
zark Posted March 11, 2021 Report Posted March 11, 2021 (edited) Your request cannot be implemented on Evolve boards, my only advice is to customize the mod using the Escribe and not change the settings while using it. But I have a friend who looks bad, he uses YiHi mod with control a smartphone using a bluetooth connection. Edited March 11, 2021 by zark
Wayneo Posted March 12, 2021 Report Posted March 12, 2021 Hi Roxii I have sent you a private message. At the top right of the screen you should see an envelope. When I have messages as soon as I login I am taken directly to it.
James Bellinger Posted March 16, 2021 Report Posted March 16, 2021 (removed: Wayneo and Roxii already made a theme) NoOptionsTheme.ecigtheme
Wayneo Posted March 16, 2021 Report Posted March 16, 2021 @James I actually worked with @Roxii and made something similar for her over the weekend. Mine was also the default based with only the battery % taking her to the settings. That way her phone could read/speak the values while she's out and about. She plugs in and makes all changes via escribe 2
James Bellinger Posted March 16, 2021 Report Posted March 16, 2021 Nice! I'm glad to hear EScribe works with screen readers as well. 1
Wayneo Posted March 16, 2021 Report Posted March 16, 2021 Right down to a 10 point font, so it could read battery % as on the default
Roxii Posted March 22, 2021 Author Report Posted March 22, 2021 I do apologize @James Bellinger I somehow ended up unsubscribing from the thread so I did not get any notifications off replies. @Wayneo Has been a great help to me, the theme that she made for me seems to be working perfectly for me, it is easy for somebody to be handed my device and I can tell them how to unlock all of the features change some thing and then relock all of the adjustable setting so that it will not accidentally change again while I use the device, I have only been using it for a couple of days so far as I did not have a chance to install the theme right away however the theme has been working flawlessly for me at so far. I will try your theme as well James and see if there is anything that should be added to one or the other way around to make a perfect theme for a blind person. I look forward to working with both of you to create this awesome theme that I’m sure many people Who are blind or visually impaired will be very appreciate of of it. Cheers. 2
Roxii Posted March 22, 2021 Author Report Posted March 22, 2021 Also I have no idea where the mailbox is. When I sign in it does not automatically take me there nor can I find any link that will take me to the inbox. Not sure if it is an on label link or what’s going on there but yeah it doesn’t seem to appear with screen reader.
Wayneo Posted March 22, 2021 Report Posted March 22, 2021 No worries @Roxii about the mailbox. We got you. If you're having trouble finding the theme @James Bellinger sent you, I can send it to you. Once you require no more changes I will publish it as the Roxii theme and you can let others know it has been a help 😇 3
