reda muhammed Posted March 10, 2021 Report Posted March 10, 2021 I bought Odin MiniDNA 75C a week ago from Egypt, but I always notice that the resistance changes from (0.36 / 0.37 / 0.38 / 0.40 / 0.41) with each time I press the resistance reading. Likewise, in the Boost mode, when I press the watt Fire, it does not change on the screen, but rather remains constant .. So is Dovpo not using a real DNA chip, or what is the problem?
Wayneo Posted March 10, 2021 Report Posted March 10, 2021 57 minutes ago, reda muhammed said: I bought Odin MiniDNA 75C a week ago from Egypt, but I always notice that the resistance changes from (0.36 / 0.37 / 0.38 / 0.40 / 0.41) with each time I press the resistance reading. Welcome 👋. First, you do not need to post your same issue 3 times. Your first 2 have been hidden. What material (wire) are you using in your atty? Run Atomizer Analyzer from within escribe and tell me how much the resistance is fluctuating. 58 minutes ago, reda muhammed said: ... in the Boost mode, when I press the watt Fire, it does not change on the screen, but rather remains constant What do you mean by 'press the watt Fire'? What were you trying to do? Is this your first color DNA mod? 1
reda muhammed Posted March 11, 2021 Author Report Posted March 11, 2021 What do you mean by 'press the watt Fire'? What were you trying to do? Is this your first color DNA mod? The problem of resistance was not fixed when I downloaded a new theme instead of the default theme..Now, the resistance reading does not differ only by 0.01 to 0.03 only. The problem now is when I go to the iScribe program and click on Get Information, it does not give me any information about the manufacturer of the mod (Dovpo Company) .. Why does it not give me information about my device?
Wayneo Posted March 11, 2021 Report Posted March 11, 2021 @reda muhammed I will answer ALL your questions AFTER you answer mine. The answers are needed to help you properly. What material (wire) are you using in your atty? What do you mean by 'press the watt Fire'? What were you trying to do? Is this your first color DNA mod?
reda muhammed Posted March 11, 2021 Author Report Posted March 11, 2021 What material (wire) are you using in your atty? What do you mean by 'press the watt Fire'? What were you trying to do? Is this your first color DNA mod? 1) THE MATERIAL IS ( NI 80 SUPERFINE MTL FUSED CLAPTON WIRE ) . 2) I am trying to find out what is the problem of unstable reading of the resistance in the mod, given that it contains a DNA chip. 3) YES IT IS THE FIRST DNA COLOR
Wayneo Posted March 11, 2021 Report Posted March 11, 2021 Alrighty then. The unstable reading of the resistance in the mod is/was either due to your build or your atty connection. Check there are no hotspots, wire clamped properly under the screws, etc. whenever you install a new coil, and before use. Changing the theme did nothing to fix your problem, but now that it is down to 0.01 to 0.03 your coil is settling in. You should dry fire beforehand (at low watts till you see a dull even glow). The mere fact that you can see your mod in escribe shows it's an authentic board. Your 'Get Information' should show that. You will benefit greatly from watching a youtube video or two on any DNA Color mod. The board operates exactly the same for all of them. Themes all vary in how they manipulate the board features. I think I have answered all your questions now, but if not what is outstanding? 2
reda muhammed Posted March 12, 2021 Author Report Posted March 12, 2021 What do you mean by 'press the watt Fire'? What were you trying to do? Is this your first color DNA mod? The problem of resistance was not fixed when I downloaded a new theme instead of the default theme..Now, the resistance reading does not differ only by 0.01 to 0.03 only. The problem now is when I go to the iScribe program and click on Get Information, it does not give me any information about the manufacturer of the mod (Dovpo Company) .. Why does it not give me information about my device?
reda muhammed Posted March 12, 2021 Author Report Posted March 12, 2021 I understood your words well .. But I still have one question, if you will allow me: - When I enter the E-Scrip program and choose to analyze the atomizer, I see the resistance is not fixed and the resistance reading varies every second, for example from (0.382 / 0.384 / 0.386 / 0.387 / 0.389 / 00.41) Is this normal?
Wayneo Posted March 12, 2021 Report Posted March 12, 2021 Always happy to help. 👋 Using "Atomizer Analyzer" the resistance should both rise and fall. From your range that's only 7 milliohms. Did you check your build and connections? 1
reda muhammed Posted March 12, 2021 Author Report Posted March 12, 2021 Thank you for your cooperation and your constant interest with me. Yes, I checked everything now, but the resistance still ranges from 0.384 to 0.391
reda muhammed Posted March 12, 2021 Author Report Posted March 12, 2021 I kindly ask you to find a way to contact you personally because I cannot send videos on this site permanently to show you the problem with the video
Wayneo Posted March 12, 2021 Report Posted March 12, 2021 @reda muhammed Videos do work if you put it on youtube and send a link, but you were very clear in your description. We do not do personal contacts. Your Ni80 is a wattage material, and 7 milliohms should not affect or change the experience. You might want to try a spaced coil if it is a contact coil, different atomizer to see if the behavior is the same, but those numbers should also be going down. Unfortunately I have no Ni80 wire myself to see on my mods.
reda muhammed Posted March 14, 2021 Author Report Posted March 14, 2021 Now, I shot a video of the problem of instability of the resistance after I checked everything watch[1]
dwcraig1 Posted March 14, 2021 Report Posted March 14, 2021 When using Atomizer Analyzer how many turns can you unscrew the atomizer before it loses connection? 2
Wayneo Posted March 14, 2021 Report Posted March 14, 2021 @reda muhammed I see the resistance rising and falling. I see no board issue, especially in watts. Are you actually having a problem? Did you try a different atty? Is the coil spaced or contact? 1
reda muhammed Posted March 15, 2021 Author Report Posted March 15, 2021 Thank you for your cooperation. Yes, I used another atty and my coil is contact . My question now is , is it normal for the resistance to differ from (0.58 /0.60 / 0.61 / 0.62 / 0.63), meaning is the normal difference by 0.001 or by 0.01 ?
