epixiscrucial Posted November 9, 2020 Report Posted November 9, 2020 (edited) Hey guys, So I have been browsing around trying to figure out how to go about finding out which lipo batteries to use and so far what I've found I don't quite understand how to go about it. If someone could maybe point me in the right direction (and I apologize if it's right in front of my face and my stupidity blinded me). Like I said I did try to find stuff and I found a little bit of info, but I just couldn't figure out how to apply any of it by any means. Like for instance I wanted to know if this battery would work: https://www.digikey.com/en/products/detail/jauch-quartz/LP705176JS-PCM-WIRES-70MM/9560997 Thanks ahead in advance and apologies in advance if this topic is redundant. Maybe I just didn't look for the correct thing. epix ' edit: I probably should have mentioned what I had found. I did read this post on this forums regarding it: https://forum.evolvapor.com/topic/68882-best-lipo-for-dna75/ I just dont get how to do the math with the discharge rate. Edited November 9, 2020 by epixiscrucial
Wayneo Posted November 9, 2020 Report Posted November 9, 2020 6 hours ago, epixiscrucial said: Like for instance I wanted to know if this battery would work: https://www.digikey.com/en/products/detail/jauch-quartz/LP705176JS-PCM-WIRES-70MM/9560997 Short answer, No. Longer answer For LiPo's you got a few ways to think. Buy battery to match your enclosure size OR Buy enclosure to match your battery size At a minimum it also needs to house the board and wires. Using @VapingBad's post in the link, you'd still want an input current ~35 amps. 1
