DNA60 USB not recognised
Azam
Hi All.
I have been struggling for the longest to get my SpyderGT with a DNA60 to work on escribe. I have  tried every bit of advice i could find and still  no joy.   It appears that the device only goes onto charging mode  on the PC.  Strangely i use the same cable  on my Solarstorm-DNA75C  and it works perfectly on escribe. What could be the issue ? Any suggestions would be welcomed.
Evolv has an optional charger board that goes with the DNA60. Their web site shows it as discontinued $10.00
From the Datasheet for the DNA 60:
Charger:
An external 1A Micro USB charger for the DNA 60 is available separately. It automatically detects the type of USB power supply it is connected to, so it can be plugged into standard PC USB ports or higher power chargers. It also includes pinouts for a data connection to utilize EScribe. Please see the Evolv website for more information.
You might contact Evolv and see if it is still available.  Also check with your mod maker and see if they used the Evolv charger board...
Evolv Datasheet:      https://downloads.evolvapor.com/dna60.pdf
Evolv 1 amp charger board (scroll down in this link):  https://www.evolvapor.com/shop
