Nov16-K Posted June 13, 2020 Report Posted June 13, 2020 Hello guys, glad to be the member of evolv dna forum My device is JAC Series B DNA75w. There's no check new atomizer function. (what I've meant is that when I switch a new atomizer, the mods will automatic detect the ohm of atomizer,then reqires me to choose old/new coil) How can I set it into my device? Best regard
dwcraig1 Posted June 13, 2020 Report Posted June 13, 2020 The board needs to know if the atomizer that you just put on is the old one and is perhaps warm from just using it. In such a case when you choose old the mod has remembered what the ohms were when cold and applies that setting. Select new and the board with use the existing ohm reading as cold ohms. Hope that helps answer your question, if not asked away.
Nov16-K Posted June 13, 2020 Author Report Posted June 13, 2020 36 分鐘前, dwcraig1說: The board needs to know if the atomizer that you just put on is the old one and is perhaps warm from just using it. In such a case when you choose old the mod has remembered what the ohms were when cold and applies that setting. Select new and the board with use the existing ohm reading as cold ohms. Hope that helps answer your question, if not asked away. yes, as what u said, I knew that. the question is other of some DNA75 mods have that function, but mine not. e.g. I used a 0.80ohm coiled atomizer before, now I switch a 0.5ohm one, the mod never asks me if there is a new coil and set a siutable watt or not, so that I have to adjust the watt. the point I asked is I need a solution to set this check new atomizer function available in my mod.
dwcraig1 Posted June 13, 2020 Report Posted June 13, 2020 Perhaps you could make a different profile in EScribe for each of the various coils. 1
Wayneo Posted June 13, 2020 Report Posted June 13, 2020 12 hours ago, Nov16-K said: the question is other of some DNA75 mods have that function, but mine not That was NOT a true statement. Even if you setup your profiles as @dwcraig1 has suggested, YOU will still need to change to that profile.
