Hi there, am using ss316l spaced , and in tc mode  i just find my cotton keeps getting cut in the middle of the coil. I was under the impression the tc would stop this happening with holding the power back so no dry hit and not causing the cotton issue, am confused :)
SS316 - I just have to ask: 1.) simple or complex wire? Complex wire is difficult ... 2.) Do you measure the coil, or the resistance after annealing or the first use? The resistance of the SS316 changes very much after the first heating, which of course gives you completely wrong values. Basically, the temperature mode is very prone to errors, so I would recommend using the wire in power mode with Replay - works great.
In my themes you always see the calculated temperature of the last puff next to the set target temperature - the results are sometimes frightening and it takes a long time to adjust the two values by manually correcting the resistance.
