Vixcent Posted March 21, 2020 Report Posted March 21, 2020 Hello guys, I have this 3 pieces dna 200 board all of the had same issue. i put working screen but it shows Very very light backscreen almost cannot see in room light. i tried to upgrade the firmware and reset back and forth and still the same. i put 100% brightness in escribe but still the same any idea how to solve this issue? Is there a busted component connected to backlight screen needed to replace? thanks in advance.
Wayneo Posted March 21, 2020 Report Posted March 21, 2020 On 3/21/2020 at 2:07 PM, Vixcent said: i put 100% brightness in escribe but still the same Expand After you do that, did you upload those settings to the mod? OR, could there be a darkened opaque cover over the actual screen?
Vixcent Posted March 21, 2020 Author Report Posted March 21, 2020 On 3/21/2020 at 5:36 PM, Wayneo said: After you do that, did you upload those settings to the mod? OR, could there be a darkened opaque cover over the actual screen? Expand I did upload the setting. there’s no cover on the screen. screen perfectly fine I tested it in working dna board. thanks for replying though.
BibbieMok Posted April 6, 2020 Report Posted April 6, 2020 Hi,... When I run eagle from the command prompt I get a black screen that Sign In on the top program window. Below is an example of the information that I get when I try to run eagle from the command prompt. The ERROR that is printed repeats about 20 times before stopping and then nothing happens. I have tried going back and running other versions of 9.x.x and it has generated the same issues.
