leea12345 Posted March 2, 2020 Report Posted March 2, 2020 Hi there had my dna 75c for a couple of weeks now, having issues not sure what to do / When using the ss316 profile. it does not seem to work great. sometimes it seems like its going in to just power mode , and sometimes have fired and it is basically does nothing . hope my device is ok. any input be great thank you
zark Posted March 2, 2020 Report Posted March 2, 2020 4 часа назад, leea12345 сказал: При использовании профиля ss316. кажется, не работает отлично Какой материал катушки, какой вид катушки. Нужны print screens (device monitor)
leea12345 Posted March 2, 2020 Author Report Posted March 2, 2020 i am using a alien ss 316l coil . i have read that the dna would work better with just single strand wire on tc. i dont know if this is an issue ?
zark Posted March 2, 2020 Report Posted March 2, 2020 5 часов назад, leea12345 сказал: Я читал, что ДНК будет работать лучше только с одним проводом на тк. я не знаю, Это не совсем правда, но проблемы с TC бывают из за многожильных катушек. Нужны print screens (device monitor) Вам нужно пригласить в беседу, кого то из модераторов, я не владею английским по этому нам будет трудно общаться!
retird Posted March 2, 2020 Report Posted March 2, 2020 8 hours ago, leea12345 said: i am using a alien ss 316l coil . i have read that the dna would work better with just single strand wire on tc. i dont know if this is an issue ? I assume the 75C is your first DNA device... DNA's work best using spaced coils (coils do not touch each other). Connectivity of coil to the atty should be tight and a good connection between the atty and the device when using TC. Many things can cause the TC to drop out to power mode. You might want to build a single wire coil (spaced coil) with the SS316L material and strive for consistent TC. Then play with the aliens again...
