What does this do? I keep locking my ohms but every now and then it asks me if I installed a new coil. Will disabling this stop that? Also, would I lose anything if I disabled?
happy holidays!
21 hours ago, Dirone said:
What does this do?
Temp Sensing (my definition)  - Material (wire) that changes its resistance enough (when heated) that will allow TP/TC to work.
  • 1 month later...
It asks if you have installed a new coil because there has been a change in the resistance from what you are locked in at.  With temp sensing materials like SS316 or Ti1 there's no reason to ever lock your ohms in, unless the atty being used is all jangly and ohm readings are unstable. Locking the ohms in with temp sensing materials will become a problem because the nature of those materials allows for temp fluctuations.  You're confusing the DNA chip and defeating the purpose of Temp Control.
