Beissen Posted November 19, 2019 Report Share Posted November 19, 2019 Anyone have a good Power Curve chart that will allow a single 18650 last longer sems mine dies fast and Im at 1.161 ohms at 16.5w on Ni80. I want to have better life. Link to comment Share on other sites More sharing options...
dwcraig1 Posted November 19, 2019 Report Share Posted November 19, 2019 There are only two settings in Escribe that are going to effect the charge life of the cell. One is whether the cell charges to 4.1 volts or 4.2 volts and the other is the Cell Soft Cutoff. The curve will only make your battery gauge more accurate. 1 Link to comment Share on other sites More sharing options...
Wayneo Posted November 19, 2019 Report Share Posted November 19, 2019 ⬆ This, right here. What battery and mod are you currently using? Fake or inferior batteries, or massive sag can make you believe you have short runtimes. Link to comment Share on other sites More sharing options...
Beissen Posted November 20, 2019 Author Report Share Posted November 20, 2019 So after reading I see what you mean dwcraig1 and also Wayneo I have a 30q, my setting were off as I now know adjust based on Amp to adjust those settings and it read right as the 30Q is only 15 Amps and I had it set to 30 Max and Discharge at 25 now its reading right. Link to comment Share on other sites More sharing options...
