Mrjosh89 Posted November 15, 2019 Report Posted November 15, 2019 First off, hello to one and all. New dna250c owner here! And I’m planning on hooking my profile rda Up to the mod and trying out this good ole REPLAY MODE!!! With ofrf ss316 strips( god I can’t wait)😁. So quick question for all you who have been using Dna’s since before I even knew what it was. With replay mode, does warmth, punch and boost factor into it? Or is it really just as simple as set watts, puff,puff, get perfect hit and save? Because there is a theme available that lets you adjust the warmth on the fly, so I thought I’d ask whether it’s necessary or not because I really want the joker theme but if I need the warmth setting to Improve or find my “perfect vape” then I’ll go with that one. Anyways thanks in advance for any input
Wayneo Posted November 15, 2019 Report Posted November 15, 2019 2 hours ago, Mrjosh89 said: With replay mode, does warmth, punch and boost factor into it? Or is it really just as simple as set watts, puff,puff, get perfect hit and save? ... because I really want the joker theme but if I need the warmth setting It can really be as simple as that Yes, 'warmth' and 'boost punch' can help you fine tune your vaping experience. BUT it can be great without them. For now, just puff away in a replay profile in a straight watt material/mode and hit the replay button when you're ready. Watch a video on how it all works and what the terms mean. Maybe put both at 5 for now, move 1 value to 8 tomorrow, if you don't like that change move it back. Some themes work better than others for users, just depending on how/what the creator thinks and if it jives with you. Enjoy your mod 1
Mrjosh89 Posted November 15, 2019 Author Report Posted November 15, 2019 @Wayneo thanks brotha. I finished the build last night. Ill break it in today, see what happens and report back here if I need any further advice.
Wayneo Posted November 15, 2019 Report Posted November 15, 2019 Make sure you're using material (wire) that is normally used for TC (SS, Ti, Ni200 as examples) for your simple coil, or as the core of a more complex coil. 1
Mrjosh89 Posted November 15, 2019 Author Report Posted November 15, 2019 @Wayneo I’m using ss316 mesh from ofrf so I hope it’s good.
Wayneo Posted November 15, 2019 Report Posted November 15, 2019 That material will be fine. Turn your watts up/down, hit 'replay'. Sit back and don't worry about dry hits from mesh (while in replay). 1 1
dwcraig1 Posted April 21, 2025 Report Posted April 21, 2025 My first thought is the wick/coil drying up. Can you maintain 50 watts when in temperature control? Or does the same thing happen?
dwcraig1 Posted April 21, 2025 Report Posted April 21, 2025 Even though it's a tank you still should be able to drip juice on the cotton to see if that changes things.
