saschacolussi Posted September 11, 2019 Report Posted September 11, 2019 Hi guys, i've been vaping when looked at my device's screen and it stated that the mod was pulling"24 amps from the batteries at approximately 100W. Does that mean it's 8amps per battery or 24amps going through each one? Would be very happy if anyone could answer me this. I've got 3 Sony VTC5a in there, thanks in advance.
dwcraig1 Posted September 11, 2019 Report Posted September 11, 2019 It's pulling 24 amps from the board not the batteries. Example: the pack @ 11.1 volts w/30 amps powers the board to put out 55 amps @ 4 volts (just a rough example, not exact figures)
saschacolussi Posted September 11, 2019 Author Report Posted September 11, 2019 Alright but those 30amps pulled from the batteries are safe? I mean, my batteries are approx. 20amps each
retird Posted September 11, 2019 Report Posted September 11, 2019 https://downloads.evolvapor.com/dna250color.pdf
saschacolussi Posted September 11, 2019 Author Report Posted September 11, 2019 15 minutos atrás, retird disse: https://downloads.evolvapor.com/dna250color.pdf Thanks but i didnt get it, should i be worried about the voltage than? "he DNA 250C runs from up to a four cell battery. Because lithium polymer cells can be damaged by excessive discharge, with multi-cell series batteries it is important to measure each cell in the battery independently and stop firing the atomizer when any of the cells reaches the cutoff voltage. The DNA 250C uses the battery pack taps to monitor each cell." Those 24amps i cited, isnt it from each cell than?
retird Posted September 11, 2019 Report Posted September 11, 2019 Where are you getting the specs for your battery.....? Google sony vtc5a specs and here is Mooch's results....... https://www.facebook.com/batterymooch/posts/sony-vtc5a-2500mah-18650-bench-test-resultsa-fantastic-25a-batterybottom-line-th/1729663520656560/ And his discussion: https://www.e-cigarette-forum.com/threads/sony-vtc5a-2500mah-18650-bench-test-results-a-fantastic-25a-battery.746719/?fbclid=IwAR0Ob-qLkOnxx8v23KmWlV7C81sbnS9uNbZBTdpYDnA9or_ff4AolfpELDU
