onikami Posted April 27, 2019 Report Posted April 27, 2019 (edited) Hi all, I got my first DNA mod - think vape Finder 250c. I am a bit confused by the watt boost setting. When I select it and set it to 60w, I cant seem to vape on this setting. Is this a setting I can actually vape on like Replay or Watts or Kanthal? Or is it for TC only? Every time I hit the power button on watt boost, it takes me to the next screen which asks me did I connect a new coil, no use old coil etc. It doesn't actually fire on watt boost when I select it. Edited April 27, 2019 by onikami
Wayneo Posted April 27, 2019 Report Posted April 27, 2019 17 minutes ago, onikami said: I am a bit confused by the watt boost setting. When I select it and set it to 60w, I cant seem to vape on this setting. Is this a setting I can actually vape on like Replay or Watts or Kanthal? YES 17 minutes ago, onikami said: Every time I hit the power button on watt boost, it takes me to the next screen which asks me did I connect a new coil, no use old coil etc. It doesn't actually fire on watt boost when I select it. Easy answer ........ say 'Yes', read resistance of coil, confirm, select to get back to normal. Then try. You should be fine at this point. 1 1
onikami Posted April 27, 2019 Author Report Posted April 27, 2019 Cheers, mate. I got it to work. 👍 1
Wayneo Posted April 27, 2019 Report Posted April 27, 2019 You're very welcome. And welcome. Now that it's working, longer answer. The coil resistance is stored 'per profile', so if you want to use the current coil in a different profile, when you get to the new profile you need to read the ohms. ONCE, per profile being used. Remember to hit select/accept/confirm. 2
