jettman100 Posted February 25, 2019 Report Posted February 25, 2019 Hello! I just have a quick question, How can I use the Orion Q pods on my Orion DNA Go Device? If so how do I do it, cause a few of my friends were telling me about downgrading the software so that the qpods will work but I don't know how to do that.
retird Posted February 26, 2019 Report Posted February 26, 2019 The Q pods are not designed to use on the Orion but some use them... I think they adjust the watts, boost and warmth but from what I'm told they won't work very well and they don't Replay on the Orion at all..... I don't use them on the Orion. Maybe someone that has used the Q pods on the Orion can pop in and provide some first hand info.... previous version of software will make no difference..... I hid your duplicate post.... no need to post multiple posts.... welcome to the forum....
Dunder Mifflin Posted February 28, 2019 Report Posted February 28, 2019 Start here You need to switch the escribe software to manufacturer mode. You can get there by going to Options - User Interface - Manufacturer. Once done, you can go to the Mod tab and adjust the resistance values for either DL (direct-lung) or MTL (mouth-to-lung) to 0.8 min, 1.2 max. I would also advise you to turn down the warm, and bring the boost down some. You'll definitely need to tinker with it to find the right settings for yourself. I started out low, then got up to 2 boost with the air wide open. It seemed to produce great flavorful hits direct lung at 11w - 2 boost - 1 warmth. Note that you won't be able to use replay. The Q pods use kanthal wire for the coil, whereas the Orion pods and the 0.5 pods are stainless steel.
