Hi.
I am using a Lost Vape Paranormal 250c. I use on TCR with SS317L 25awg 6 wrap spaced build ohming out at .42.
Thats been my standard build for quite sometime. Since the last couple of days the flavour is not as good as it used to be. I also started to feel the coil was taking on some sort of brown/bronze colour.. (never see that happening before)..
Can this be an issue caused by the DNA ? not really sure how to go about it..
Any help is appreciated..Thanks
NO, I can't see this being a mod issue. All a mod does is supply power to a coil.
Other forums can help you better because it can be anything from concentrates in the juice, carmelization due to power too low or temp you set too low, coil needs cleaning, etc.
Run the case thermals, that really messes up with TC on extreme weather if it's not calibrated, I use TC mostly aswell so I calibrate them all,  run your cells to 25% then run case analyzer and TC should be solid and stable afterwards.
