Ooyah Posted January 26, 2019 Report Posted January 26, 2019 Hi. I'm new to this, so please bear with me! I have the DNA 250C, and I'm using the Crown 4 tank, and would like to use the SS coils in TC mode. However, the coils are SS904L, and I can only see profiles for SS430 and SS316. Can I use one of these for SS904L? Or do I need to download a profile from elsewhere? Please forgive me if this is a daft question!
Wayneo Posted January 26, 2019 Report Posted January 26, 2019 Replay mode in straight watts will offer you the dry-hit benefit of TC, without TC. They might work with either or both, but the temp set or displayed will be wrong. 1
Ooyah Posted January 26, 2019 Author Report Posted January 26, 2019 1 hour ago, Wayneo said: Replay mode in straight watts will offer you the dry-hit benefit of TC, without TC. They might work with either or both, but the temp set or displayed will be wrong. Thanks for the reply! I love Replay, although I don't understand how it works... I need to read an explanation of it. For the TC bit... if I choose one of the SS profiles... when you say that the temperature may be wrong... do you mean that the temperature that I specify may not be the temperature applied? Depending on how much it is out by, could that either be dangerous, or run the risk of burning the coil? I would like to experiment with different temperatures, which replay does not allow, but am worried about damaging something.
Wayneo Posted January 26, 2019 Report Posted January 26, 2019 1 hour ago, Ooyah said: Replay ... I need to read an explanation of it Search here works well. Wait for a puff you really like and hit Replay. The mod will try to replicate that for you. 1 hour ago, Ooyah said: if I choose one of the SS profiles... when you say that the temperature may be wrong... do you mean that the temperature that I specify may not be the temperature applied? Correct. 316 might not work at all, and the temp of the vape will be lower than the number on the screen. 430 should work and the temp number will not be accurate. If you setup the watts for TC according to uwell's max recommendations, it won't be any more dangerous than straight watts. You won't damage your mod. 1
Ooyah Posted January 26, 2019 Author Report Posted January 26, 2019 1 hour ago, Wayneo said: Correct. 316 might not work at all, and the temp of the vape will be lower than the number on the screen. 430 should work and the temp number will not be accurate. If you setup the watts for TC according to uwell's max recommendations, it won't be any more dangerous than straight watts. You won't damage your mod. Yep... 316 doesn't work at all, but 430 does. TC is very interesting. Hopefully explicit support for 904 will be added sometime. Thank you very much for the help!
retird Posted January 26, 2019 Report Posted January 26, 2019 Ran across these on reddit..... I have no idea if these will work but here they are...... csv for ss904L and TFR exel file...... if they don't work don't blame the messenger.... 😁 CSV: https://drive.google.com/file/d/1Ss_PhX1oXn3W9jryiglK36tQjdY3KApb/view TFR: https://drive.google.com/file/d/122V0jGwYdxhzxStD5vOt7dheHU3iwM_t/view 1 1
Ooyah Posted January 26, 2019 Author Report Posted January 26, 2019 42 minutes ago, retird said: Ran across these on reddit..... I have no idea if these will work but here they are...... csv for ss904L and TFR exel file...... if they don't work don't blame the messenger.... 😁 CSV: https://drive.google.com/file/d/1Ss_PhX1oXn3W9jryiglK36tQjdY3KApb/view TFR: https://drive.google.com/file/d/122V0jGwYdxhzxStD5vOt7dheHU3iwM_t/view Oh, wow... thank you! I am quite new to this, so I will have a read up first... I'm a bit confused by the TFR file... but when I am confident that I know what I am doing, I will give it a shot! This is such an amazing mod.
