aggelikos@gmail.com Posted January 9, 2019 Report Share Posted January 9, 2019 Hi! I'm new with mirage dna 75c so can you tell me if I need to make some basic settings? Thank you! Link to comment Share on other sites More sharing options...
Wayneo Posted January 9, 2019 Report Share Posted January 9, 2019 It'll work fine out of the box. Install escribe and see if there are any firmware updates. A battery profile to match YOUR battery type will ONLY make the icon on the display more accurate. Watch a video or 2 on your mod, and the 'search' feature here works. Enjoy your mod 🖐️ 1 Link to comment Share on other sites More sharing options...
aggelikos@gmail.com Posted January 9, 2019 Author Report Share Posted January 9, 2019 Thnx! Link to comment Share on other sites More sharing options...
Ping Posted February 9, 2019 Report Share Posted February 9, 2019 I just received my Mirage 75C and the menu on the device looks nothing like the picture of the menu in the manual from Lost Vape. I noticed that SS 316 was listed and not 316L. I use 316L and not sure how to get that setting on my mod. Link to comment Share on other sites More sharing options...
Wayneo Posted February 9, 2019 Report Share Posted February 9, 2019 @Ping You can plug in your other DNA mod. Start escribe, go to materials. Look if it's in the left window. If it's not, but is in the right window, highlight it, then use the left arrow and move it into the 'master' list on the left. Disconnect via escribe. Plug in Mirage, highlight 316L in left window, BUT this time hit right arrow to move onto mirage. 'Upload settings to device'. It should now be on mod. You should notice very little difference between the two material types 316/316L. 2 Link to comment Share on other sites More sharing options...
Ping Posted February 9, 2019 Report Share Posted February 9, 2019 On 2/9/2019 at 12:31 AM, Wayneo said: @Ping You can plug in your other DNA mod. Start escribe, go to materials. Look if it's in the left window. If it's not, but is in the right window, highlight it, then use the left arrow and move it into the 'master' list on the left. Disconnect via escribe. Plug in Mirage, highlight 316L in left window, BUT this time hit right arrow to move onto mirage. 'Upload settings to device'. It should now be on mod. You should notice very little difference between the two material types 316/316L. Expand Thank you very much. I'll give it try as I have escribe on my work computer and use chromebook at home. I'm not even sure what the difference is between 316 and 316L. Link to comment Share on other sites More sharing options...
Wayneo Posted February 9, 2019 Report Share Posted February 9, 2019 On 2/9/2019 at 12:48 AM, Ping said: ....... I'm not even sure what the difference is between 316 and 316L. Expand From a material perspective, the 'L' material should be lower in Carbon than the non 'L' material. From a TCR perspective (using steam-engine) 316 is .000880, and 316L is .000879, so that's a .000001 difference. But having the same actual files on 2 mods should make settings/warmth in your mouth near identical. EDIT: And there's NO supported version of escribe for Chromebooks. 1 Link to comment Share on other sites More sharing options...
Ping Posted February 9, 2019 Report Share Posted February 9, 2019 316 and 316L seem identical. Thank you for helping. Link to comment Share on other sites More sharing options...
Wayneo Posted February 9, 2019 Report Share Posted February 9, 2019 On 2/9/2019 at 12:11 AM, Ping said: the menu on the device looks nothing like the picture of the menu in the manual from Lost Vape Expand That looks like the djlsb vapes theme. If you're accustomed to the one the Paranormal, so that they both operate the same, you can use theme designer and save the theme you prefer and then load it onto the other mod. You should check some themes here, many have the new Replay feature programmed in. And, you're welcome. Link to comment Share on other sites More sharing options...
Ping Posted February 9, 2019 Report Share Posted February 9, 2019 My new DNA has the replay option and it's awesome since I don't have a collection of RTA's and for the most part I use the same build. I definitely want to download a theme for the paranormal which includes the replay option. I can't thank you enough for being so helpful. Before buying DNA's I was a provari user as I knew they were a very safe mod. 1 Link to comment Share on other sites More sharing options...
Ping Posted February 10, 2019 Report Share Posted February 10, 2019 On 2/9/2019 at 3:05 AM, Wayneo said: That looks like the djlsb vapes theme. If you're accustomed to the one the Paranormal, so that they both operate the same, you can use theme designer and save the theme you prefer and then load it onto the other mod. You should check some themes here, many have the new Replay feature programmed in. And, you're welcome. Expand First of all thanks as I was able to move 316L to my Mirage. The problem I'm having with escribe is that it will not allow me to download any theme with Replay on it. I receive the message that Replay is not a USA feature. I had saved my theme for the Mirage and tried to download it on the paranormal and it's a no go. Even the other themes with Replay will download but I can't find the option for replay on them. Any suggestions are welcomed. Link to comment Share on other sites More sharing options...
Wayneo Posted February 10, 2019 Report Share Posted February 10, 2019 On 2/10/2019 at 8:10 PM, Ping said: The problem I'm having with escribe is that it will not allow me to download any theme with Replay on it. I receive the message that Replay is not a USA feature. Expand You need to install the intl (International) version. You don't need to delete the old. If you're not prompted there's a service pack, it's should be the last option under 'Tools' 1 Link to comment Share on other sites More sharing options...
Ping Posted February 10, 2019 Report Share Posted February 10, 2019 On 2/10/2019 at 9:40 PM, Wayneo said: You need to install the intl (International) version. You don't need to delete the old. If you're not prompted there's a service pack, it's should be the last option under 'Tools' Expand You did it again. Did I purchase the international version? I followed your instructions and sure enough my paranormal now has replay. Link to comment Share on other sites More sharing options...
Wayneo Posted February 11, 2019 Report Share Posted February 11, 2019 On 2/10/2019 at 10:47 PM, Ping said: Did I purchase the international version? Expand Every 'C" board can run the US or Intl version of software. All depends what you load on it. So apart from 75watts, it can now Punch your watts to 100 to heat high mass coils quickly, as well as Replay your puffs. 3 Link to comment Share on other sites More sharing options...
SalsaVida Posted March 1, 2019 Report Share Posted March 1, 2019 Hello everyone, can anyone tell me where I can find the csv file for my battery and how can I upload it to escribe for my Mirage? Link to comment Share on other sites More sharing options...
scott6058 Posted March 23, 2019 Report Share Posted March 23, 2019 Anyone know where you can get a replacement battery door for the Mirage? Link to comment Share on other sites More sharing options...
Wayneo Posted March 23, 2019 Report Share Posted March 23, 2019 Open a Help Desk ticket and explain the problem. Link in my signature. Link to comment Share on other sites More sharing options...
