Hello to all!
My Triade seems to have a problem with battery drain. From 97%  to around 50% drop 2-3% per 3-4 hits, but from 50% to 0% drops in matter of minutes. It will go down 10-15% per 1-2 hit. Compering it to my asmodus lustro, lustro lasts longer then Triade.
Batteries are Sony VTC6.
So how to set up this thing proprerly so it can last at least a day.
At 50 % voltage was 3.7 volts. At 15 % to 0% one cell dropped to 3.2 volts and then it showed weak battery warning.
I rotated them and same happend, same battery, different slot.
It turns out all 3 batteries were bad. They were purchased in shop with mod as brand new but they were from old stock. Code on all batteries reads they were made in 2015.
Another easy way to see if the cells are good or bad, is to fire a coil in Device Monitor while watching the each of the three cells voltages. If they plummet like a rock when firing.....time for new cells. Honestly, you can't go wrong with the Sony VTC5A cells. They're a great all around cell with a healthy CDR and decent capacity.
