dl12345 Posted October 26, 2018 Report Share Posted October 26, 2018 (edited) I've just acquired a 250c. I've been using two DNA200s, a DNA75 and a DNA250 for the last few years in TC mode. I'm accustomed to having the live temperature displayed when I press the fire button. It's a great way to assess fairly quickly if the atomizer isn't making contact properly (juice on the plate, not screwed in fully, etc.) as you can blip the fire button and if you see a high temperature immediately, you know there is something wrong. In theme designer, I simply cannot seem to get the temperature display to update live. I've tried everything (clicking the checkbox for update while firing is the obvious first step). I tried to put in a similar field for live ohms and get the same result - either the set maximum temperature displays (not updated live) or I get a field with an On or an Off statement in it (live ohms) Does anyone know if it is possible to get a live temperature in the same way as with the DNA75/200/250? Edited October 26, 2018 by dl12345 Link to comment Share on other sites More sharing options...
Klipscher Posted October 27, 2018 Report Share Posted October 27, 2018 (edited) If you go into theme designer and go to the screen the temperature is displayed on. Click on the temperature and you will see a option to update well firing. Edited October 27, 2018 by Klipscher Link to comment Share on other sites More sharing options...
dl12345 Posted October 27, 2018 Author Report Share Posted October 27, 2018 On 10/27/2018 at 1:31 AM, Klipscher said: If you go into theme designer and go to the screen the temperature is displayed on. Click on the temperature and you will see a option to update well firing. Expand See my comment in the first post. I've done this already but it has no effect. Link to comment Share on other sites More sharing options...
BillW50 Posted November 8, 2018 Report Share Posted November 8, 2018 (edited) Did you ever solve this problem? I never tried changing the temp to live update though, but that does sound like it is worth a shot to me. But I have to admit even without a live update, that puff curve for each puff is far more valuable to me. As I can see what the temperature was doing for each puff (and other things too). 😊 Edited November 8, 2018 by BillW50 Link to comment Share on other sites More sharing options...
