Lost Vape Orion "What are all of the maximum settings?"
In your other post, you were already told 30 watts, boosting to 40. The answer will not change.
Boost and warmth - 11.
Tiny 900mAh battery (large for pods)
Many are vaping in the 11 - 13 watt range on these non rebuildable pods.
This is not an Aromamizer Titan atty holding 30ml of juice sitting on a 400 watt 4S Lipo.
  • Like 2
Thanks.
Ok ..but what will happen if I set 30watts.
will the pods be able to take it?
I set it to 30 watts one time with boost set to 11 with the .25 ohm coil
The pod tasted burnt though
You can try it for yourself
thanks...can I assume that the pod was ruined.
what annoys me with the pods is that there is no wattage range and with the best watt range like with coils.
Since you can adjust wattage like on a mod this modpod should have the same thing for their pods.
It doesnt really matter if you set it to 30 watts, the max ohm set for the .5 coils is .71 which it reaches within seconds and then is limited at 19 watts, then the device lowers wattage to around 13 to stay below the max .71 ohm. I have not tried to increase the max because I dont want to fry a coil. best thing to do to get a get idea of the max settings is to watch the device logger, its pretty cool
