Hi,
I'm just wondering if it would be possible to disassemble my Paranormal and turn the 510 connector by 120°. All of my RDA's sitting weird and the airflow holes are in the wrong direction for my liking.
What do you think?
Cheers
Hi,
You can do it, but you need to desolder the negative wire (the black one) from the 510 and resolder it once you find the ° you like, otherwise you'll not be able to reassemble the 510.
It's not easy to explain but you'll understand what i mean if you take apart the 510.
Edited by DPG
I actually did this on a Paranormal 75C. There was enough wire that I didn't even need to dig out the soldering iron. There was no excessive tension on anything either, I made sure of that before putting it back in. Of course that may vary by each mod. Hope there's enough wire in there for ya. Good luck!
  • 1 year later...
Mine is also like 90 degrees off from where I'd want my airflow.  They are in line with the body of the mod rather than perpendicular to it's centerline, if that makes sense.  DNA 250C also. 🙁
