Hi everyone, two days ago my Efusion gave up the ghost, and today I was using my Hotcig DX200 converted to dual 18650's (both of my hotcigs had board replacements from evolv).
It was running fine, but then displayed a 'shorted' message, and the battery meter went from full to empty. Now when I attempt to fire, it just displays shorted. I've tried a reset in Escribe, the RDA works on my DNA75 and other mods, so I am unsure what is going on.
If it is another failure, I will have to leave Evolv behind which is a shame, as I really like them when they work. I think you can understand my frustrations though and if you had 5 devices fail that used the same boards would feel the same.
Any ideas what I can do to fix the mod? I hope it doesn't need sending away as I live in the UK, if it does I will just count my losses and move on.
EDIT: I removed the 18650 section, and bent the pins as I remembered these could lose contact. It seems to be working now- for how long I am unsure.
Edited by Conanthewarrior
Shorted usually means there is a shorted connection somewhere in the device wiring, device connections, 510 connector, and etc.   This is a design issue and not a board issue.  Glad you fixed it....
Thank you @retird. My memory isn't too good (brain damaged), but I recalled the pins in the back of the hotcig sometimes needed moving to get a good connection. I bent them downwards gently.
I think this may have happened the other day when I noticed my Li-Po powered hotcig was not working. I swapped the Li-Po for the Li-ion pack to see if it was the battery, and it was.
Now I just need to find a new enclosure for the battery. I tried to solder one in before, but messed it up.
