Ammonarrow Posted May 27, 2018 Report Share Posted May 27, 2018 Hey, So I have a 2.61 Ohm Coil, and when I try to fire, it only gives me 19 watts (around 7.5 Volts, not 11). Can you troubleshoot? Link to comment Share on other sites More sharing options...
retird Posted May 27, 2018 Report Share Posted May 27, 2018 Can you post a screenshot of your Profile for that coil? What are the Profile settings? Link to comment Share on other sites More sharing options...
Ammonarrow Posted May 27, 2018 Author Report Share Posted May 27, 2018 16 minutes ago, retird said: Can you post a screenshot of your Profile for that coil? What are the Profile settings? Using the default Profile for watts. Mod shows me around 19.3 Watts with my coil. Link to comment Share on other sites More sharing options...
James Posted May 28, 2018 Report Share Posted May 28, 2018 The DNA 250C is step-down, so if your device takes two battery cells, the output voltage cannot be higher than the battery voltage. (Four cell devices have their battery voltage above 10V at all times while operating, and three cell devices generally do, so you don't run into this. The benefit of the step-down configuration is drastically better efficiency and cleaner signal.) Link to comment Share on other sites More sharing options...
Ammonarrow Posted June 1, 2018 Author Report Share Posted June 1, 2018 Something I dont get: A 75c will give me 9 Volts (single Battery) at 1.08 Ohm which means 75Watt. However: I cant get 9 Volts on 2 Series Batteries with a 250c. Cant get 75 Watts on 1.08 Ohm Does the 250c have a travo in it like the 75c, cause I did understand so. Link to comment Share on other sites More sharing options...
