MdeJong Posted May 15, 2018 Report Posted May 15, 2018 (edited) Hello, I am looking for a drawing of the cutouts to be made in the faceplate with the Position of the Display to the Buttons, usb connector and the mounting holes. i am using the displaymount from the product web site. Where can I find this? Regards Mark, Edited May 15, 2018 by MdeJong Extra info added
retird Posted May 15, 2018 Report Posted May 15, 2018 IF the board specs will help.... there is detailed measurements pics in these pdf datasheets... https://downloads.evolvapor.com/dna250color.pdf https://downloads.evolvapor.com/dna75color.pdf
MdeJong Posted May 15, 2018 Author Report Posted May 15, 2018 Hello, From the drawings in the datasheets only the Position of the mounting holes, Buttons and usb connector are visible, but not the position of the Display. Regards Mark,
retird Posted May 15, 2018 Report Posted May 15, 2018 The display is not attached to the board. You might contact Evolv for the any further information you want at this link.... select Tech Support https://helpdesk.evolvapor.com/?a=add
