Sara Turner Posted May 11, 2018 Report Share Posted May 11, 2018 Hi all - I’ve been using Replay and it works as advertised as on my RTAs and drop in tanks. However I can’t seem to get a consistent draw when using an RDA specifically a Royal Hunter X, SC Supreme V2, Kennedy etc.... I’m running a ss316L 28g 3.0 ID with 6 wraps at .39 ohms. On TC it’s perfect at 430F and stays perfect. I will dial in the draw I want and Save it but the following draws get increasingly weaker and cooler until I can hardly notice any vape at all.. Just wondering if anyone else is having any issues like this and if it can be tweaked. Apreciate the help in advance! sara Link to comment Share on other sites More sharing options...
niandra3 Posted May 13, 2018 Report Share Posted May 13, 2018 (edited) @Sara Turner Have you adjusted the Warmth value in the Replay settings? (shameless plug but) I've got a theme that has a Warmth slider on the Replay settings page.. that might help. TBH I don't use Replay a ton, I've found regular old TC to be more consistent. That being said, I have gotten Replay to work on my 75c and 250c with a Pulse RDA (also with Stainless). You doing contact or spaced coils? I've found spaced works better with TC, so that might also be the case with Replay.. not sure. Edited May 13, 2018 by niandra3 Link to comment Share on other sites More sharing options...
Sara Turner Posted May 14, 2018 Author Report Share Posted May 14, 2018 I’ll give that a try. Thanks. But like you I’m perfectly happy using tc!! 1 Link to comment Share on other sites More sharing options...
niandra3 Posted May 14, 2018 Report Share Posted May 14, 2018 (edited) @Sara Turner Nice. I also forgot to mention firmware. I'm almost positive you have to be using the International Version of EScribe (link here, you want EScribe Suite 2.0 SP15.1 For International Customers, or later versions if this post gets old). Then in that version of EScribe, it should prompt you to update your 75's firmware (I'm using 1.1 SP33.2 which DOES work with 75+Replay). So convoluted lol... Edited May 14, 2018 by niandra3 Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted May 14, 2018 Report Share Posted May 14, 2018 Just like TC, when in Replay if the wicking starts to dry out, the power will decrease as needed. I like Replay for it's simplicity but TC will always be my home. 1 Link to comment Share on other sites More sharing options...
Sara Turner Posted May 14, 2018 Author Report Share Posted May 14, 2018 Chunky I think you’ve nailed it on the head. It seems more noticeable because I’m “expecting” the same vape over & over. Yes TC is working great for me as well. I change out juice flavors several times a day and I enjoy each at a different vape temperature so TC is perfect for me to adjust on the go. I have used Replay with an RTA with a full tank and it worked wonderfully. I think it will be perfect for a lot of vapers who don’t want to “fiddle” with TC or don’t use RDAs often. Thanks for your post. Link to comment Share on other sites More sharing options...
Sara Turner Posted May 14, 2018 Author Report Share Posted May 14, 2018 14 hours ago, niandra3 said: @Sara Turner Nice. I also forgot to mention firmware. I'm almost positive you have to be using the International Version of EScribe (link here, you want EScribe Suite 2.0 SP15.1 For International Customers, or later versions if this post gets old). Then in that version of EScribe, it should prompt you to update your 75's firmware (I'm using 1.1 SP33.2 which DOES work with 75+Replay). So convoluted lol... Thanks it’s definitely the International version and updated service pack. Appreciate your help. Link to comment Share on other sites More sharing options...
Sara Turner Posted May 14, 2018 Author Report Share Posted May 14, 2018 17 hours ago, niandra3 said: @Sara Turner Have you adjusted the Warmth value in the Replay settings? (shameless plug but) I've got a theme that has a Warmth slider on the Replay settings page.. that might help. TBH I don't use Replay a ton, I've found regular old TC to be more consistent. That being said, I have gotten Replay to work on my 75c and 250c with a Pulse RDA (also with Stainless). You doing contact or spaced coils? I've found spaced works better with TC, so that might also be the case with Replay.. not sure. BTW I really like your Theme. Next time I spark up the laptop I’m going to download it on my 2 Therions and Paranormal! Thanks!! 1 Link to comment Share on other sites More sharing options...
