I had my mod just two months ago and I have suffering from hot tank issue and the customer services told me this could be due to the coil. I have tried many coils and many tanks but the same issue is still there. The mod is THE REBEL MOD SQUONKER- EVOLV DNA 167 - 2 X 18650.
Any ideas ?
I am using Fused Clapton Wire N80. wire size 26/36
  ○ This Wire is a dual round wire wrapped with 36ga(0.127mm)
Edited by Duniya
Should have been heat capacity, and that is how long it takes the coil to heat up and how long it stays hot after you quit applying power. According to steam engine your coils have what I consider to be a relatively high heat capacity for a 22mm dripper, and probably borderline even for a 24mm dripper
Maybe not what is happening but make sure the coil isn't touching the inside of the chamber.  I've had that happen a time or two using big coils and the result was a hot atomiser.
