LeeWB3 Posted April 17, 2018 Report Share Posted April 17, 2018 (edited) On the settings for the replay feature, what does the warmth setting do? Is it documented somewhere? Edited April 17, 2018 by LeeWB3 Link to comment Share on other sites More sharing options...
VapingBad Posted April 17, 2018 Report Share Posted April 17, 2018 It is how much extra power you let the board provide when the coil is cold. You may want it higher if you recorded a puff at the end of a series when the coil and atty were warm to start with or you may want it lower if you recorded a puff from cold. 2 Link to comment Share on other sites More sharing options...
Jim P. Posted September 20, 2018 Report Share Posted September 20, 2018 Sorry , But the only thing I'm understanding from your reply is the: " It is how much extra power you let the board provide when the coil is cold. " If that is an adjustment for the extra power at start up from a cold coil, then my question would be what is the BOOST function below the POWER settings adjusting? Is it the amount of time it stays at the WARMTH setting? Also what is the WARMTH setting number , is it the amount of watts to jump up? Thanks :) Link to comment Share on other sites More sharing options...
Lanzarotechris Posted October 17, 2018 Report Share Posted October 17, 2018 Yeah, I am also confused with the WARMTH and BOOST settings... not very well explained. From the power side I would guess its the same. Link to comment Share on other sites More sharing options...
