NMEones Posted April 13, 2018 Report Share Posted April 13, 2018 So I build/sell coils so I wanted to try a mixture of some n80 and SS316L in a Fralien coil. I used 1x 28g n80 1x 28g SS316L 3x .3x.1 n80 3x .3x.1 SS316L with 36g SS316L alien wrap. Now I assumed this was ok for Replay mode... was my assumption correct? If it is then I have another RDA that won’t register temp control coils into my mod. Thanks in advance for any insight! Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted April 13, 2018 Report Share Posted April 13, 2018 In Escribe If that doesn't work the TCR of the coil (wire combos combined) may be to low. Or you have a mod/base resistance stability issue. Link to comment Share on other sites More sharing options...
retird Posted April 13, 2018 Report Share Posted April 13, 2018 Have you tried the coil mentioned on any other RDA's and did they Replay? Link to comment Share on other sites More sharing options...
NMEones Posted April 13, 2018 Author Report Share Posted April 13, 2018 1 hour ago, retird said: Have you tried the coil mentioned on any other RDA's and did they Replay? Actually... I wanted to swap flavors (was testing a new DIY flavor) so I took the cotton out and went to dry burn a bit before I cleaned the rda and I noticed a few hot spots... I worked them out and then looked at the screen and it actually was going to let me replay... I guess the hot spot some how made the chip misread the coil material or something? I didn’t wick it up yet but I’ll leep you updated and let you know what’s going on! Thanks for the response! Link to comment Share on other sites More sharing options...
NMEones Posted April 13, 2018 Author Report Share Posted April 13, 2018 1 hour ago, ChunkyButt200 said: In Escribe If that doesn't work the TCR of the coil (wire combos combined) may be to low. Or you have a mod/base resistance stability issue. I actually had this same issue with my dead rabbit (S316L Fraliens) and tried switching on dubious coils and it didn’t work... someone mentioned that I might have to break the rabbit down and give it a good cleaning Link to comment Share on other sites More sharing options...
retird Posted April 13, 2018 Report Share Posted April 13, 2018 Yep, hot spots and dirty atty's don't play well with DNA's.... it's good the DNA lets you know tho..... Link to comment Share on other sites More sharing options...
