Podunk Steam Posted February 25, 2018 Report Posted February 25, 2018 (edited) First day new Mirage So far I've loaded Daniels theme ( DJLsb) Updated 316L to 0.00092 TCR Changed unlock number of clicks and sequence Single coiled my Ammit 25 with a 316L flat clapton 0.3x0.8x32 Locked resistance at 0.27 ohms And once the mod takes a nap and I have to wake it with the unlock sequence the TC is whacked. It hits Temp protect before it even heats the coil enough to make vapor. Would this be the issue I've heard of with combination wire 316L coils and the DNA 75C? Trace issues across the different sized wires in the clapton coils? Any fix applicable? I have tried searching this topic with no luck so I'm posting. Edit: If I change to Wattage, fire the coil, change back to TC the TC works again. Think I found the issue, tightened the coils connection again and resistance dropped to .23, back to Escribe with me. Edited February 25, 2018 by Podunk Steam
Jonski Posted February 25, 2018 Report Posted February 25, 2018 I only use standard SS316L in my Therion DNA 75C , I never lock the resistance , and it works everytime . Depending on atty I have it set to somewhere between 400F and 440 F . 1
Podunk Steam Posted February 25, 2018 Author Report Posted February 25, 2018 Thanks for the reply! At this point I think it was the coils connections that were the issue.
