Richard Hasal Posted January 26, 2018 Report Posted January 26, 2018 I just bought my first DNA 200 mod. ( Lostvape 133 ) and I would like to use one brand of battery exclusively ( Sony for example ) I was wondering if it would be worth changing the battery settings in the mod section to numbers more dialed in to the spec of my battery. Or should I just leave it as is
Wayneo Posted January 27, 2018 Report Posted January 27, 2018 On 2018-01-26 at 2:42 PM, Richard Hasal said: ..... worth changing the battery settings in the mod section to numbers more dialed in to the spec of my battery. You can create or load your own battery curve which only affects the gauge display in combination with Watt hours input. Cell soft cutoff for message when you're hitting that 'lower' limit. Soft being the keyword which is the big momentary dip when you first hit the fire button. 1
