Aalmosawi Posted December 16, 2017 Report Posted December 16, 2017 So I just bought me a paranormal dna device and am happy with it thus far. Although one of the side panels is somewhat shaky and doesn't fit right like the other side. It's something I can ignore I guess So, moving on. I figured i'd play around with escribe. Because technically I don't need lots of profiles. All I want is kanthal power mode and ss 316L. Anyways , I kept clicking on load defaults and so on. After I unplugged the device it showed a blank battery icon and it wouldn't turn on. Even though the batteries are full. The device just won't come in. In the end I went on lost vapes website and downloaded the ecig file for the therion being they are identical units. Uploaded that and now it's functional. I am not sure what I did that caused this behavior. Can someone shine some light so I wouldn't commit the same error again? Furthermore I don't know why lost vape dont even have any info on the paranormal device. But still I believe the therion is the same. 1
Wayneo Posted December 16, 2017 Report Posted December 16, 2017 22 minutes ago, Aalmosawi said: I kept clicking on load defaults and so on. That's what you did. You kept loading the Evolv defaults, which is set for 3 batteries NOT 2.
iAlexander Posted December 21, 2017 Report Posted December 21, 2017 I have uploaded stock Paranormal 166 settings, for such cases You can download it anytime...
Paranoid_Paranormal Posted January 23, 2018 Report Posted January 23, 2018 On 12/16/2017 at 3:46 PM, Wayneo said: That's what you did. You kept loading the Evolv defaults, which is set for 3 batteries NOT 2. Does this apply for the paranormal dna75c as well? I need to restore defaults to mine and start over...
Wayneo Posted January 23, 2018 Report Posted January 23, 2018 (edited) 3 hours ago, Paranoid_Paranormal said: Does this apply for the paranormal dna75c as well? I need to restore defaults to mine and start ove Well yes. And Defaults refers to Evolv's generic defaults. Edit: Unless the vendor has used the 'Production Utility' to program the board, in which case, it would actually be back to where it all was when shipped to you. BUT you're in luck because when you've fired up Escribe, under the 'help' menu item, down at the bottom, you'll see a 'backups' item, and it's saved a full copy everytime you started escribe. Edited January 23, 2018 by Wayneo Bit of clarification
Paranoid_Paranormal Posted January 23, 2018 Report Posted January 23, 2018 17 minutes ago, Wayneo said: Well yes. And Defaults refers to Evolv's generic defaults. Edit: Unless the vendor has used the 'Production Utility' to program the board, in which case, it would actually be back to where it all was when shipped to you. BUT you're in luck because when you've fired up Escribe, under the 'help' menu item, down at the bottom, you'll see a 'backups' item, and it's saved a full copy everytime you started escribe. Ok great thanks. I think I might have some questions for you later if I'm unsuccessful in getting TCR/TFR curves working... Would you mind if I private message you or should I start a new post? Thanks again.
Wayneo Posted January 23, 2018 Report Posted January 23, 2018 Search works, and there are many sharp experienced users here. IMHO, public is better cuz if any of us are wrong someone will catch it quickly. Welcome
