Floh85 Posted December 4, 2017 Report Posted December 4, 2017 Hello, is it normal that Time and Date resets after the batterys removed ? Think it saves Time and Date, but when i remove battery and it didnt save it makes no sense -.- hope for help, regards Florian
giz_60 Posted December 4, 2017 Report Posted December 4, 2017 Should save time and date long enough to change batteries. Will reset if batteries are out to long. Connecting to Escribe & opening 'Device Monitor's will reset to current time & date!
Floh85 Posted December 4, 2017 Author Report Posted December 4, 2017 Ok thx for reply, think first i put batterys into mod after getting it, there was time and date set -.- don't understand. And other is then i connect to escribe and open device monitor it will show 04/12/16, have set it to 2017 ?
giz_60 Posted December 4, 2017 Report Posted December 4, 2017 Double check the time & date on your computer... the board gets that info from the computer when you open Device Monitor...
Floh85 Posted December 4, 2017 Author Report Posted December 4, 2017 hm have check it, its up to date. i use win10. language english, escribe langauge english too. have check my antivirus (bitdefender) too that it didnt block... dont understand.
retird Posted December 4, 2017 Report Posted December 4, 2017 So, you are unable to get the right time on the device? Try this: In Device Monitor go to Diagnostics and click on "update clock" then click OK to the box that opened. Upload settings to the device. If this still doesn't get you there please post a copy of your Theme file (.ecigtheme) or of your .ecig file so we can look at it.... 1
Floh85 Posted December 4, 2017 Author Report Posted December 4, 2017 hm when i set my time & date on computer to 2018 it will sync it to 2017 -.- ...here are my .ecigtheme and .ecig files have use EScribe Suite 2.0 SP9 and DNA 75 Color (firmware 1.1 SP27). Lost Vape Paranormal DNA75C.ecig Lost Vape Paranormal DNA75C.ecigtheme
retird Posted December 4, 2017 Report Posted December 4, 2017 What were the results of the steps I asked you to try???
Floh85 Posted December 4, 2017 Author Report Posted December 4, 2017 (edited) Haven’t work date was still 2016 ...have done complete steps you said I try. Edited December 4, 2017 by Floh85
giz_60 Posted December 4, 2017 Report Posted December 4, 2017 There is something wonky in that theme....I loaded that theme into mine & am seeing the same issue...have you tried a different theme?
retird Posted December 4, 2017 Report Posted December 4, 2017 You have saved your ecig and theme files.... wondering about the theme. @giz_60....sorry for double dip about the theme.... was typing as you posted....
Floh85 Posted December 4, 2017 Author Report Posted December 4, 2017 It was originally on my mod, think that came after update
giz_60 Posted December 4, 2017 Report Posted December 4, 2017 3 minutes ago, retird said: You have saved your ecig and theme files.... wondering about the theme. @giz_60....sorry for double dip about the theme.... was typing as you posted.... Interestingly, I switched back to the theme I had in it originally & now it is still doing the same thing...never had an issue with it before...
Floh85 Posted December 4, 2017 Author Report Posted December 4, 2017 No haven’t try other. Think I reset it to default
giz_60 Posted December 4, 2017 Report Posted December 4, 2017 Yup..and if I try to manually reset the year, on the device, it won't accept 2017 & keeps bumping back to 2016
Floh85 Posted December 4, 2017 Author Report Posted December 4, 2017 (edited) Other is when I set time & date in mod and accept 04/12/17 with middle button it goes to 04/12/16. when I do again it goes to 04/12/15... Yeah same on me that you have really crazy Edited December 4, 2017 by Floh85
retird Posted December 4, 2017 Report Posted December 4, 2017 That theme shows to be from www.djlsbvapes.com
giz_60 Posted December 4, 2017 Report Posted December 4, 2017 3 minutes ago, Floh85 said: Other is when I set time & date in mod and accept 04/12/17 with middle button it goes to 04/12/16. when I do again it goes to 04/12/15... Yeah same on me that you have really crazy Agreed...and each time you repeat, it drops another yr...
Floh85 Posted December 4, 2017 Author Report Posted December 4, 2017 (edited) Yes, wtf is this :// have tried reset to defaults, etc. Edited December 4, 2017 by Floh85
Floh85 Posted December 4, 2017 Author Report Posted December 4, 2017 At first time of use the mod have set time and date. It haven’t battery’s in and save it. Since after updates there still problems with this and theme.
