Lost Vape Paranormal DNA 75 C - Time and Date reset after Batterys removed
Hello,
is it normal that Time and Date resets after the batterys removed ?
Think it saves Time and Date, but when i remove battery and it didnt save it makes no sense -.-
hope for help, regards Florian
Should save time and date long enough to change batteries. Will reset if batteries are out to long. Connecting to Escribe & opening 'Device Monitor's will reset to current time & date!
Ok thx for reply, think first i put batterys into mod after getting it, there was time and date set -.- don't understand.
And other is then i connect to escribe and open device monitor it will show 04/12/16, have set it to 2017 ?
hm have check it, its up to date. i use win10. language english, escribe langauge english too. have check my antivirus (bitdefender) too that it didnt block... dont understand.
So, you are unable to get the right time on the device?  Try this:
In Device Monitor go to Diagnostics and click on "update clock" then click OK to the box that opened.  Upload settings to the device.  If this still doesn't get you there please post a copy of your Theme file (.ecigtheme) or of your .ecig file so we can look at it....
3 minutes ago, retird said:
You have saved your ecig and theme files.... wondering about the theme.
@giz_60....sorry for double dip about the theme.... was typing as you posted....
Interestingly, I switched back to the theme I had in it originally & now it is still doing the same thing...never had an issue with it before...
Other is when I set time & date in mod and accept 04/12/17 with middle button it goes to 04/12/16. when I do again it goes to 04/12/15...
Yeah same on me that you have
really crazy
Edited by Floh85
really crazy
Agreed...and each time you repeat, it drops another yr...
At first time of use the mod have set time and date. It haven’t battery’s in and save it.
Since after updates there still problems with this and theme.
