USB Connection
vaporlips
Hello,
I understand with the DNA75 Color that the screen does not illuminate when connected via USB unless there is input voltage to the board, but what I am curious of is if you connect your bare bones DNA75 color to USB, do you get any notification within escribe?
I believe my DNA75 Color board I received is DOA.  No notification at all when connected via USB, regardless if there is or isn't input voltage to the board.
Just wanted to check, before I send it in for RMA.  Thank you.
Thanks Giz for the prompt response. I'll try to configure it on escribe then. I'm getting the "temp protected" error message too on a newly built wasp nano rdta (ss wire 28 gauge) it seems that the only wire it is able to recognize was kanthal 0.4 or 0.5 If the loops were more than five that's when it started to display the temp protected error message and the 0.00 volts sometimes.
