peraspera Posted September 18, 2017 Report Share Posted September 18, 2017 My Therion 75C is draining and heating up batteries with no atty or tank installed. It does this with batteries that work correctly in my other Therion 75C. This started overnight when the Therion drained the batteries down to 1.74 volts. I checked it today and it did the same draining/heating with two other battery pairs both with and without an attached atty or tank. Any ideas on what might be wrong or any possible fixes? Link to comment Share on other sites More sharing options...
retird Posted September 18, 2017 Report Share Posted September 18, 2017 May have a short or other issue in the device causing the batteries to auto discharge. As it auto discharges have you checked the voltage at the 510 connector with no atty present? Do have know if you have continuity at the 510 connector between thew center pin and the shell of the 510 when no batteries are connected indication the 510 is shorted? Is the fire button stuck or shorted? Could be many other things too. The batteries that heated and went down to 1.74 volts are candidates to be disposed of and not used again. Link to comment Share on other sites More sharing options...
peraspera Posted September 18, 2017 Author Report Share Posted September 18, 2017 Thank you for the suggestions but it sounds like my Therion needs attention from someone who knows what they are doing which would not be me. Does Evolv offer Therion repair services? Link to comment Share on other sites More sharing options...
retird Posted September 18, 2017 Report Share Posted September 18, 2017 Submit a ticket and they will guide you.... here is the link.... https://helpdesk.evolvapor.com/index.php?a=add&category=1 Link to comment Share on other sites More sharing options...
peraspera Posted September 18, 2017 Author Report Share Posted September 18, 2017 Thank you for your help. I filed a ticket per your suggestion. Link to comment Share on other sites More sharing options...
TexNZ Posted September 21, 2017 Report Share Posted September 21, 2017 (edited) Doubt it's relevant but my 75C Paranormal autofires the moment I close the battery door and the batteries touch their respective contacts. Does your Therion ever auto-fire with the atty attached? Edited September 21, 2017 by TexNZ Link to comment Share on other sites More sharing options...
peraspera Posted September 21, 2017 Author Report Share Posted September 21, 2017 I never saw the firing indicator on the screen appear when my Therion 75c was heating/draining the batteries either with or without an atty or tank attached. Evolv did not have me do any troubleshooting in response to the ticket I filed but just issued an RMA so I have no further information on what was causing the problem. I only mailed my Therion back to Evolv yesterday with the tracking showing a projected Saturday, 0/23 arrival date. I will post a follow up when Evolv lets me know what was amiss. Link to comment Share on other sites More sharing options...
Ploppy Posted September 28, 2017 Report Share Posted September 28, 2017 Whilst its not going to cause the amount of drain you mention above (sounds like it def needed sending back) i did notice whilst playing with themes that one drained my battery slightly whilst the mod wasn't in use. Unfortunately i cant rem exactly which one it was (possibly the inverse one) as I've DL a lot of them - but it kept the battery indicator light on constantly which in my eyes isn't sensible. However minimal the drain is you don't want it whilst the device is "dormant" Link to comment Share on other sites More sharing options...
