alanlee Posted September 4, 2017 Report Posted September 4, 2017 Hello everyone so about a month ago i purchased the Lost Vape Drone and i have been having a small issue when i have it up to 160 watts or more it keeps saying check battery max wattage i am able to go to is 155, is it possible to fix this issue?
Wayneo Posted September 4, 2017 Report Posted September 4, 2017 With all that info, I'd start by using steam-engine, ohms law, and see if you're banging off the 6V output voltage limit, 1
alanlee Posted September 4, 2017 Author Report Posted September 4, 2017 so i checked it out and the max voltage show was 3.5 at 166 could it have soemting to do with the battery settings?
Wayneo Posted September 4, 2017 Report Posted September 4, 2017 I don't think settings themselves, but more likely the batteries, or a high soft cell cutoff value
retird Posted September 4, 2017 Report Posted September 4, 2017 Does the Drone have only 2 batteries? If so then the mod is only 166 watt maximum.....
alanlee Posted September 4, 2017 Author Report Posted September 4, 2017 thank you everyone i actually figured it out after a few hours of messing on escribe it was the battery settings i just had to set the Voltage to 2 and now its working like a dream and hits the tits
Wayneo Posted September 4, 2017 Report Posted September 4, 2017 1 hour ago, alanlee said: so i checked it out and the max voltage show was 3.5 at 166 could it have soemting to do with the battery settings? So you're running a 0.07 coil? 38 minutes ago, alanlee said: .... just had to set the Voltage to 2 and now its working like a dream and hits the tits Huh Glad to hear it's working for you? but what you've typed doesn't make sense. Vape on! 1
alanlee Posted September 5, 2017 Author Report Posted September 5, 2017 hahah sorry its in escribe on the mod tab right underneath the option to choose the cell amounts you can add in the voltage of the battery i set it to 3.7 like th ebatttery said and it didn't fire rate the set the voltage option to 2 and now it fires up no probglems
