etab75 Posted September 1, 2017 Report Posted September 1, 2017 Just adding the new boost feature to my theme and I've noticed that because the power field is shared (eg Atomizer>Preheat/Boost>Power), the watt limit is still 75W when using Kanthal and not 100W. I therefore went into escribe set 100W manually for a Watts profile, thinking that'll work... uploaded and the max is still 75W on the device Bug or am I missing something obvious as per?
jakeT Posted September 1, 2017 Report Posted September 1, 2017 I believe you have to change Max Output under the Mod tab, at least that's what worked for me! 1
etab75 Posted September 1, 2017 Author Report Posted September 1, 2017 +++ SOLVED +++ Bravo Sir! Yep, that worked thanks mate
