Help with off board buttons
Droopydroors
This up & down button component only has 3 wires for both buttons. When I solder it on to the DNA60 board do I put the down wire in pin 1, the up wire on pin 6 and run the ground to pin 8 and leave pin 2 and pin 5 open?  Sorry if this is a stupid question but im just playing around and want to make sure. Thanks in advance.
Hello, if I remember correctly, pin 2 and 5 are connected internally as they are both ground. So with your 3 wire set up, you should be able to wire to pin 1, 2, and 6 and leave 5 open, or 1, 5, and 6 and leave 2 open. But I would not use pin 8 for your buttons.
Easiest way to confirm this, is with multiple meter and check continuity between pin 2 and 5.
Hope this helps.
  • 10 months later...
