mandro Posted August 3, 2015 Author Report Posted August 3, 2015 I've been reading about the few problems with pinched screen ribbons. I built my mod, using the on board switches and found that there wasn't much room for fitting the screen/ribbon between the switches. Would it be possible to have a slightly shorter ribbon for builds using the on board switches and if so, would a shorter ribbon still be able to fold back on itself ?
VapingBad Posted August 3, 2015 Report Posted August 3, 2015 I just gave mine a gentle S bend and you could use a little kapton tape to hold the bend, bend not fold. I doubt they can change easily as they are bought in. You could also put a guard below the button.
mandro Posted August 3, 2015 Author Report Posted August 3, 2015 I managed to get mine in OK but I've built quite a few mods. I would imagine that it could cause problems for someone building their first mod. If the screen cut-out is not in the right place, there is a chance of pinching the ribbon.
Brandon Posted August 3, 2015 Report Posted August 3, 2015 You should be able to fold the ribbon cable without damage. We put 2 folds in the screen ribbon when assembling the reference mod and have not had any issues. Once folded, you should avoid unfolding it.
KTMRider Posted August 3, 2015 Report Posted August 3, 2015 Brandon said:You should be able to fold the ribbon cable without damage. We put 2 folds in the screen ribbon when assembling the reference mod and have not had any issues. Once folded, you should avoid unfolding it. I folded mine gently while installing in both my mods (BRD200 and Hana v200). I think the problem comes when the ribbon is pinched between the fire button and you're constantly pinching it when vaping and eventually it fails. It took 2+ days on my BRD200 and less than 24 hrs on my v200. Here's how I pre-bent the ribbon when I installed a new display in the v200.
