reeder359 Posted August 15, 2015 Author Report Posted August 15, 2015 I'm wondering if you could use different buttons for the fire and plus and minus buttons. Could you wire everything to the board with different buttons instead of using the on board buttons? I want this mod to be durable and long lasting. This is my first box mod build and would be greatly appreciated if anyone could help me out. Thanks
blueridgedog Posted August 15, 2015 Report Posted August 15, 2015 Yes. There are solder points on the chip for off-chip buttons. I am not certain that more complexity of install = more durable.
reeder359 Posted August 15, 2015 Author Report Posted August 15, 2015 What I meant by more durable is I don't want the on board buttons to go out on me and plus I would want more of a clicky button to press when I vape it. I want to feel that I'm actually hitting the fire button or plus and minus buttons
reeder359 Posted August 15, 2015 Author Report Posted August 15, 2015 Do you have to de solder the existing buttons to wire in new buttons?
retird Posted August 15, 2015 Report Posted August 15, 2015 No just use the 6 thru-hole solder points.
reeder359 Posted August 15, 2015 Author Report Posted August 15, 2015 Are they these holes https://twitter.com/suzuki359/status/632573105462972416?s=09 and what pattern does it go fire , up, then down?
retird Posted August 15, 2015 Report Posted August 15, 2015 Yes, those are the ones. See pdf here for wiring information.http://www.evolvapor.com/datasheet/dna200.pdf
