ricsuth Posted August 15, 2015 Author Report Posted August 15, 2015 Hi, I've just put my build together and everything appears to be working fine except there's no ohm reading on the display. Any clues? Got it hooked up to a fat daddy v4 low profile. Just wondering what to check first...?
ricsuth Posted August 15, 2015 Author Report Posted August 15, 2015 To clarify, it's just reading "0.00" but it's applying the correct voltage for my current atty...
retird Posted August 15, 2015 Report Posted August 15, 2015 EDIT: posted as you were adding info. Do you have it connected to EScribe? What does Device Monitor show you?
ricsuth Posted August 15, 2015 Author Report Posted August 15, 2015 EDIT: posted thinking you'd seen the last one...
ricsuth Posted August 15, 2015 Author Report Posted August 15, 2015 Scratch all that - it's just kicked in! Thread closed (unless it decides to repeat the fault)
blueridgedog Posted August 15, 2015 Report Posted August 15, 2015 I get 0.00 ohms when a new atomizer is installed until the fire button is pressed once.
