Hammond Size Question?
Fullymax 900mah 30C, MaxAmps 800mah 40C and Turnigy 950mah 25C(dremel work needs for particular lipo) will fit in 1590A. Mamu made a tutorial for DNA200 1590A but side panel instead of front. http://www.mamumods.com/tutes/dna200faceplate-howto.pdf
reganbranch said:
is the battery's mah tripled because they're 3 cells
Yes, but really should work our Watt Hours which are capacity in Ah x nominal voltage so 3.7 V batteries have higher Wh than 3.6 V for the same capacity, the LiPos the DNA200 takes are 11.1 V.  But as they are in series and haver higher current rating than 18650 more of the power is usable so a bit better than 3 times.
[QUOTE=reganbranch]what does the c mean? I.e. 30c 25c 40c [/QUOTE]
[quote]
C in C Rating stands for capacity. To break it down to its simplest terms, the C rating is the maximum safe continuous discharge rate of a pack. If you see 10C on your battery, it means it can be discharged at 10 times that pack's capacity. Capacity refers to the milliamp-hour rating of the battery, which will be listed as a number followed by mAh (2000mAh, for example).
Here's the easy way to find your battery's discharge rate just multiply the number from the C rating by the pack's capacity. Keep in mind that 1000 milliamps equals one amp. Here's an example, using an 11.1V 2000mAh 10C
11.1 volt 2000mAh -10C
2000 milliamps = 2 amps
2 Amps x 10 = 20 amps continuous discharge [/quote]
  • 1 month later...
